Old 01-13-2007   #3
Re: SMC Alky Kit Install
Just under the tank is a breathing tube/drain tube of some sort. I stuck the SS line through there.
I really wanted to keep the zip ties to a minimum, but here it was really necessary.
SS line runs through a spare spot on these brackets that run under the car. These also secure brake and fuel lines.
Had to find a 25/64" drill bit to drill the right hole, but it fits perfect. A little blue loctite will keep this from coming loose.
Had to put at a bit of an angle so I could still fit a wrench in there to tighten this little 7gph nozzle:
