Thread: 91 Galant VR4
Old 01-07-2011   #11
Re: 91 Galant VR4
A few updates on the never ending build. I have 2 blocks for the car for next year, one will be the new race motor, and the other will be the backup motor.
We just finished doing a partial fill on a block and machine work for the Crower rods and Wiseco pistons to go into. I just need rings and clean/paint the block and that motor is ready for assembly.
Then the good news, I am getting custom CP pistons, and custom Carillo rods for the new race motor. Which will have a lot more hard block then the back up motor.
The pistons are custom designed for this setup, the piston is more like a clover shape in the bore for better piston stability, It will have a 22mm HD wrist pin, and added strength from the shelf part to handle the high boost, high hp, and high rpm I plan for this setup. It will also have a new wrist pin lock and tool that is supposed to be easy to install and take apart.
The rods will be a straight H beem, a 22mm pin bore on the small end, and be the right width on the big end to fit the 6 bolt crank shaft, and the top of the line rod bolts, Multiphase TM (285,000 UTS).
I will post some pics tomorrow, and let you know when the shinny new parts show up.
