Old 04-05-2015   #11
1990GSX
Drives: 1975 corvette stingray, 2008 evo x gsr
Re: Over Boosting? Need some help guys
Edit: I missed this post:
Originally Posted by talonsway View Post
so i removed the arm and took it for a drive, at about 4-5k i was seeing about 20 pounds of boost and at about 6/6.5 almost 30 pounds of boost. So if i am thinking right this means i found the problem, and that is that my waste gate is bad? So start shopping for a big 16g Waste gate actuator?
Do this:
30psi is a ton of boost creep, wow.
Did you try hooking the actuator directly to the intake manifold vacuum source?
1990GSX is offline   Reply With Quote
