Old 11-08-2004   #1
Anduinlight
The Ghey Chef!
Anduinlight's Avatar
Drives: 2007 Toyota Tundra
Race gas
OK I know this doesn't matter a whole lot because the racing season is over; but.... I found a good retailer who carries Race gas all year round. it's 110 octane 4% lead (thats bad right?) but the company has many stations that carry it as well as the 97 unleaded
so my question is: is 110 leaded gas alright to run and it not kill my O2 sensor?
98 Mitsubishi Eclipse RS - Gone
92 Eagle Talon TSi AWD - Parted out
10 Toyota Camry - DD
07 Toyota Tundra - For pretty much everything else
Anduinlight is offline   Reply With Quote
Old 11-08-2004   #2
Leaded fuel is what kills O2 sensors.
Old 11-08-2004   #3
Anduinlight
The Ghey Chef!
Alright let me rephrase that
Is there an O2 sensor i can get that is able to run with leaded gas... or is leaded gas just bad in general?
(i think there was already a post about leaded gas :s )
is there anyother thing that should be done if you are going to run leaded gas???
Old 11-08-2004   #4
Jacek
Captain J-Sack
http://store.yahoo.com/machv/denoxsen.html
its not necessarily bad. it just leaves nasty deposits of lead on your valves, turbine, exhaust etc.
Old 11-08-2004   #5
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
If replacing your O2 sensor every year bothers you, dont use it.
Old 11-08-2004   #6
Shotgun!
Totenritt
Shotgun!'s Avatar
Lead is good for everything else though. I say run it when you need it and don't when you don't. Replace the O2 once a year and have fun!
Old 11-09-2004   #7
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Or just keep a spare o2 to swap in when you feel like running race gas. Then swap back when you refill with 92 oct
Old 11-09-2004   #8
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
I have had good luck with running race gas on my stock 80,000 mile 02 sensor. I would run "race" about every other weekend throughout the last two summers and the o2 sensor is still working good.
Jim
Old 11-09-2004   #9
A tankful now and again won't kill your o2 sensor too quickly...it took about 2 years to start affecting mine.
Old 11-09-2004   #10
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Does the 02 sensor do anthing besides be used for logging purposes for us?
7/25/09
Old 11-09-2004   #11
Anduinlight
The Ghey Chef!
so this might seem like a dumb quesiton now but... how do you tell when your O2 sensor starts to go?
and all of you who have been running leaded gas.... you're still using the "stock" O2 sensors right? now a wideband?
Old 11-09-2004   #12
If you have a logger of some type that will give real time display of the O2 sensor, it will start to slow down it's rate of sweep and the voltage change will become less and less as it gets worse. I had my O2 sensor start to be affected by race fuel and once I put super unleaded back in and hammered on the car a few times, it went back to working normal again with no problems.
Old 11-09-2004   #13
Jana
Mazda Bitch
Your CEL will come on.
Old 11-09-2004   #14
A bad o2 sensor can cause poor fuel mileage at cruise....other than that, nothing. A CEL will only occur when the o2 sensor goes dead (at least from my experience). It is really easy to tell when it starts to go bad just by watching a logger or an o2 voltage monitor.
Old 11-09-2004   #15
Anduinlight
The Ghey Chef!
so in other words... leaded gas ok.. just watch my O2 sensor?
Old 11-09-2004   #16
YES, YES, YES
Old 11-09-2004   #17
BUT, you can not have a catlytic converter when using leaded gas, you must have a test-pipe.
Old 11-09-2004   #18
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
You will also need to change your plugs alot more often
Old 11-09-2004   #19
Anduinlight
The Ghey Chef!
don't have to worry about that
Old 11-09-2004   #20
Yea if you dont use leaded alot you shouldnt have a problem, you can just drain your gas if your going to do some runs at the track and then fill a few leaded gallons in. Then after your done fill it back up with unleaded and you should be fine. Driving on it like that shouldnt ruin your O2 for quite a while.
OT but whos in your avatar?
