Old 02-19-2007   #1
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
WTB Valve Springs, 650 Injectors, Head gasket
I am looking for a set of stronger higher reving valve springs and reatiners preferably titanium or equivelant. I am also in the need of 650 injectors. Lastly I need a headgasket that will easily hold 30 lbs of boost.
Old 02-20-2007   #2
Re: WTB Valve Springs, 650 Injectors, Head gasket
We sell a high rev spring and chrome moly retainer kit $279.99. These are a crower compariable spring and chrome moly retainer.
Stock head gasket will easily hold 30psi with arp's and proper tuning.
680cc injectors are $249.95 and are available within 3 business days.
Old 02-20-2007   #3
Nash
Nash's Avatar
I have a set of PTE 680 injectors I'll sell you for $165.
Old 02-20-2007   #4
Good deal!
Old 02-20-2007   #5
95talonracer
Finally Tuned...
Drives: Spyder GSX
Ok I have narrowed it down a bit. I need a set of valve springs and retainers that will go good with the Crower Stage 3 64114 cams and rev up to 8000-8500 rpm. I am also looking to buy FIC 650cc injectors or equivelant because htat is what is the default on the dsmlink chip I am buying. Lastly i think that I want a cometic metal head gasket because I had one last time and had good luck with it. Let me know and send me prices via PM. Thanks
Also what do you think 650cc's will go up to for hp with all supporting mods to max them?
Old 02-25-2007   #6
IndiEP
Tha MIG Masta!
IndiEP's Avatar
This is Halon...
I have a set of FIC 650's if you want them. I am leaving for Georgia tomorrow though. So you'd either have to get them today, or in 2 weeks when I get back.
612 384-1425
Austin
Old 02-25-2007   #7
/\/\ That was me, sorry.
Old 02-25-2007   #8
v8klla
v8klla's Avatar
We have Brian Crower springs/retainers available for $209.99, they will definitely work well with those camshafts!
http://www.maperformance.com/store/p...3&cat=0&page=1
As far as a head gasket unless you are getting your block/head resurfaced we would recommend our SCE ICS Titan gasket for $109.99, otherwise with proper machining the Cometic will be a great choice for $79.99!
http://www.maperformance.com/store/p...cat=294&page=1
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 02-26-2007   #9
95talonracer
Finally Tuned...
Drives: Spyder GSX
Springs and retainers found, just need the injectors and dsmlink. I think ill go with the 880's or something like that now instead since I am getting link. Let me know if you have either.
