Old 02-14-2009   #121
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: Getting the Laser ready for AutoX
With my tax returns officially on the way in, I can start planning and gathering things for 09. I want to actually be able to have a chance at winning SM in my local SCCA region, and the most cost effective way of doing so is new tires. So I picked out 4 brand new Falken Azenis RT-615's from discount tire direct. They will be mounted on some stock rims.
Next, I will be converting from the 1g Maf setup to a 3 inch gm maf setup with a translator. This will diffinently help in so many ways right now I can't even begin to go over all of them.
I will also be changing transmissions, so I'll be picking up a new XTD Stage 3 6 puck clutch kit off ebay. I Still have the 1g Nt tranny that came with the car, and I know it doesn't leak. Not only that, but it has shorter gear ratios as well. The current turbo tranny that I had put in sounds like its on its last legs.
And lastly, I'll be going through the engine bay fixing leaks and once I got the leaks fixed, I'll take it into work on a weekend and spray out the engine bay with the pressure washer.
I do hope to make the spring cruise, but right now it's up in the air.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 02-14-2009   #122
twack
It was a auto get over it
twack's Avatar
your car is in running order right now just dont touch it till then
Old 02-14-2009   #123
123abc
123abc's Avatar
Drives: Loud cars
I'll do the tires and the MAF-T along with fixing the oil leaks and possibly putting my evo 9 fuel pump in. I won't be on the azenis for that though.
Old 02-27-2009   #124
123abc
123abc's Avatar
Drives: Loud cars
I've changed my mind on tires for the moment. I think the idea of more power/boost intrigues me a bit more...
...so I picked up an AEM UEGO Wideband and I got the maft from Twack. I have the sensor on the way in. Next, I'll be looking for an Aeromotive AFPR and some brake upgrades.
Old 02-27-2009   #125
twack
twack's Avatar
just find some cheap 2g, 2 piston brakes with rotors and some nice pads and you will be happy
Old 02-27-2009   #126
^Thats what I am going to be running this year to see if they hold up.
Old 02-27-2009   #127
123abc
123abc's Avatar
Drives: Loud cars
That is what I was thinking but I also need a set of ss brake lines too.
Old 03-05-2009   #128
123abc
123abc's Avatar
Drives: Loud cars
Which would you guys recomend? SS Brake lines, dual piston upgrade, or pads? I only have enough for one of those things right now.
I've figured my stock brakes have good stopping power as I can lock up the tires easily. The only thing is the feel isn't there, doesn't really inspire confidence. That alone leads me to want the SS brake lines. What would you do?
Old 03-05-2009   #129
twack
twack's Avatar
do it right and do all 3
Old 03-05-2009   #130
A set of big brakes should be easy to find for cheap. Id do those and pads. If you dont see yourself upgrading from the 1G small brakes in the next year, then just get really good pads.
Old 03-06-2009   #131
123abc
123abc's Avatar
Drives: Loud cars
I guess I don't see the point as I'm not going to do track days, just autocrossing and driving on back roads. The stock calipers and discs can lock up the brakes and they do slow me down decent, it's just the feel isn't very good. Maybe a set of pads and the lines then?
Old 03-06-2009   #132
Either way you go, you can't go wrong with a set of SS lines. I have them all the way around on my car and I love them.
Old 03-10-2009   #133
123abc
123abc's Avatar
Drives: Loud cars
So I got my car out of my parents back yard, hooked up the translator and everything is working great except a few things.
1. My intercooler coupler off the j pipe keeps blowing off whenever I hit 3rd gear. I spin crazy through second, hit third for about a second and pfffff, off it comes. I think I need to shorten up the pipe because the angle is kind of awkward and get it bead rolled. What's weird is I didn't mess with that at all since last year. Is it happening more often because without the stock intake setup my 14b is flowing that much more?
2. Im getting a fairly consistant fuel cut at around 5-6k. I'm running 15 psi on the stock turbo and fuel system with a pump rewire. I do have a slow boost leak at the tb but the fuel cut wasn't this often last year. Any ideas? I'm getting good timing at 20-21 degrees and an occasional 1 count of knock at random.
Old 03-10-2009   #134
Get the pipe bead rolled.
Are you sure its fuel cut? Real fuel cut feels like you just ran into a wall for a split second. Bucks hard.
Old 03-10-2009   #135
123abc
123abc's Avatar
Drives: Loud cars
Yup. Thats what it does. Engine just shuts off for a second. I thought getting the translator would help get rid of fuel cut but it seems worse than last year.
Old 03-10-2009   #136
The stock mass air sensor is a restriction compared to the maf translator, so that's probably where the cut is coming from. Time to upgrade the ecu, I think.
Old 03-15-2009   #137
123abc
123abc's Avatar
Drives: Loud cars
Took some pictures today of my new under-hood layout. Nevermind the maft box sitting messy. I'll be looking for an extension harness to mount it inside under the head unit next to my wideband location.
I didn't want to pay 50+ dollars for an intake, so here's the 3 inch intake I made for around 37 dollars out of pvc piping, a coupler and some high temp grill paint:
Some exterior shots after the carwash:
Need to get it in to work on a sunday and shampoo the shit out of the carpet and scrub the seats clean:
Tomorrow the Evo9 fuel pump goes in, and then I just have to wait for the evo 9 injectors from kracka and the fun will begin.
Old 03-27-2009   #138
123abc
123abc's Avatar
Drives: Loud cars
Alright, 2 weeks after putting the pump in, I think i got it set. Gave the JB weld on my return pipe about 3 days to fully dry and cure. Ran it a bit today and so far absolutely no sign of leaks.
Seems to idle good, just changed the oil with full synthetic Valvoline. Pig rich though. Going to install my wideband gauge where my stock oil pressure gauge is in the cluster. Have to modify it a bit, but I love the location.
This weekend I'll hook the logger up and do some basic tuning.
Old 03-27-2009   #139
PVC emits a caustic chlorine gas when heated; you may want to switch to either metal or ABS plastic.
Old 03-27-2009   #140
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Don't try and run more than 35psi. Those couplers will blow off your GM MAF.
