Old 03-07-2009   #161
Re: My Talon
I picked up my TurboX coated parts from Bob at Map today. I went over to the car and put some of it on. I realized I'm gonna have to cut a lot more off my downpipe than I thought, and I need to chop part of my compressor cover outlet off and weld on a 90 elbow.
The drain is gonna be kinda funky. I might need two 45 degree -10 fittings to get it to work right.
I also need some more 02 housing bolts, I should most likely order new turbo bolts and lock washers from mitsu.
I have to fab up my 4" intake, v band downpipe, a oil drain, install cams and new OFH and oil cooler, and set up Link!
Old 03-08-2009   #162
mike55112
mike55112's Avatar
Drives: 04 evo
Re: My Talon
Hurry up, get this shit done. You and chris are probably gonna be done around the same time. Oh ya, Kara texted me something pretty funny about your ride home last night.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 03-08-2009   #163
Re: My Talon
get this done!
-A. Swift
Old 03-21-2009   #164
Re: My Talon
I just finished polishing my compressor cover, for my first time polishing, and how lazy I was, it turned out pretty good. LOL those aren't my candles either.
I also got my lower intercooler pipe set up for the Holset, and re powdercoated at Primo.
Should be getting my pushlock drain tube any day (I hope!)
And so I just need to spend some time with the car and get it all buttoned up!
ID:	8326   Click image for larger version
Old 03-21-2009   #165
Re: My Talon
Sweet!
Old 03-21-2009   #166
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: My Talon
Wow.. That looks really good! Better than I did with my 16g..
-1990 Mitsubishi Cyborg 4WD-
Old 03-22-2009   #167
Re: My Talon
Cams are in. Just need my oil drain so I can spend the 30 mins bolting the turbo and o2 up.
Chop flange off downpipe, TIG vband on, thats pretty much it.
Old 03-22-2009   #168
mx3twinturbo
mx3twinturbo's Avatar
Drives: StarQuests>>>>>>
Re: My Talon
Kevin,
I know those candles are yours!
looking good man,
1987 Conquest- 2.1 project started...
1986 Dodge D-50- S.C. truck 2.6 turbo swap started
1992 Mazda Mx-3- Rear mount twins in progress
1989 Suburban- Project for too Long!!!
"Just Remember, I HATE Drama"
mx3twinturbo is offline   Reply With Quote
Old 03-27-2009   #169
Re: My Talon
Ok, so whenever the hell it warms up a bit, (tomorrow/sunday) I'm gonna go put my o2 housing/wastegate on, and hopefully start my downpipe modding. I also need to tighten a few fittings on my oil filter housing. Pics soon.
Old 03-29-2009   #170
Re: My Talon
Rad in, drain tube made, downpipe is hopefully gonna be welded today. Just need to hook up a gauge, clutch wire and maybe wideband for Link, and setup Link. Ooo and drain my tank lol.
Old 03-29-2009   #171
Re: My Talon
Do you run the stock turbo water pipe? If so, did you run into any issues with the compressor cover hitting the little water pipe nub on the bottom of it (the nub that isn't on the N/T ones)?
Old 03-29-2009   #173
mdost03
Sonic Champion!
Drives: VA STI
Re: My Talon
Making some great progress Kevin, nice job! That compressor cover looks pretty sick also.
Old 03-29-2009   #175
Re: My Talon
I swapped to a 90 N/T thermostat housing and 90 N/T waterpipe (I added an external oil cooler). I had to dent the water pipe a little to clear the compressor cover, but it was just a little bit.
Old 03-29-2009   #176
Re: My Talon
Originally Posted by blackrosenova400 View Post
Damit sleepy your gonna run the setup ive been dreaming of doing for quite a while.
How stout is your motor, give me details.
Hahaha, stock 6 bolt Well, it's fresh stock rebuild by me. It has like 15k miles on it so far. ACL Race bearings, ARP headstuds, Copper-sprayed mitsu gasket, fresh head, balance shafts eliminated.
If/when this engine blows up, a mild 2.4L will be tossed in.
Old 03-29-2009   #177
Re: My Talon
Did you degree those cams?
A big fat NO. I'm sure it will be fine, not perfect, but fine.
My mini-laptop should be here tomorrow so I can start linking it up! But this shit weather might hold me up till next weekend.
Some newer pics below. I'll get better ones once the car moves.
ID:	8379   Click image for larger version
Old 03-29-2009   #178
Re: My Talon
Damn dude, looking good!
Old 03-29-2009   #179
Re: My Talon
Glad to see I'm not the only one with "modified" thermostat housing wiring. Looks good man!
Old 03-30-2009   #180
blackrosenova400
blackrosenova400's Avatar
Re: My Talon
I have two solid lifters, I will be degreeing my BC 280's. Do you have adjustable cam gears? I think we should spend a day degreeing them if you do, although I think it would be alot harder with the motor in the car.
