Old 05-29-2009   #1
mukapahnpy
Broken'In'Fail
mukapahnpy's Avatar
Drives: 99 GSX
Driver Side Front Axle
So I have a frozen driver side axle / housing bracket / half shaft assembly that is driving me nuts. Has anyone taken all these pieces apart? If so, how?
DSM 2gb awd and it is currently OFF the car, if it matters.
TIA
Avatar = Small Turbo:confused:
mukapahnpy is offline   Reply With Quote
Old 05-30-2009   #2
clean2g
Boost Junkie
clean2g's Avatar
Drives: I teleport
Re: Driver Side Front Axle
Just some clarification, which housing bracket are you referring to? The piece that holds the wheel hub/bearing? Usually, while the axle is still on the car, I undo the big axle bolt and give it a few wacks with a rubber mallet and it pops out from the wheel hub. I have however ran into the issue once where the wheel hub/bearing somehow welded itself to the axle and I had to take it and get it torched off. I would try maybe using some PB blaster or something to loosen it overnight and try again the next day, but I'm not sure if it's safe to use that stuff around your rotors.
