Old 12-02-2009   #121
Re: 91 Galant VR4
Nice, that looks awesome, now I see how the drivers side motor mount bolts on with those three top bolts.
Question though, how do you get the larger bolt going down to secure? It looks like it's going into an empty tube, do you have a nut welded to the bottom side to thread into? Sorry for the noob questions, just trying to learn. Is it common to bolt to the front side of the block at the power steering holes (for tube front ends like this)?
Old 12-02-2009   #122
Re: 91 Galant VR4
Yes there is a nut welded on the bottom side of the cap I made for the tube welded onto the frame rail. I do not know what is "common" for a tubular front end, but I have heard of people having issues cracking the 2.0 block around the #1 cylinder near where the driver side motor mount bolts onto the block. This would indicate its possible for the high hp AWD guy's to think twice about cutting down the driver side mount to just the timing belt side of the block for support. I figure I had to make a mount anyways, if it helps or not, I do not know.
Old 12-04-2009   #123
Forced Fed
Drives: FS-T
Re: 91 Galant VR4
Did you plan and know you were going to do a tube front end this whole time? This is butter, I love mandrel bends! Looks great keep up the good work, love your custom manifolds.
Old 12-04-2009   #124
Re: 91 Galant VR4
From looking at Shep's and Brent's cars up close it has been in the back of my mind brewing. Then about a little over a month ago I really looked at the front of my car and decided this is the route I would take. This does work to the end all goal, so its a nice step in the right direction of light, strong, and easy to work on. If I knew I was going to remove the front of the car I would have gone a different route on the exhaust manifold but it will work just fine.
Old 12-04-2009   #125
Re: 91 Galant VR4
the car did look great last night
Old 12-21-2009   #126
Re: 91 Galant VR4
Going for the fastest GVR4 in the world? Or just looking to do some pulls on 94 against the local mustangs. That thing would rock with a 16g on it, Full Spool at 2 rpm.
Old 12-21-2009   #127
Forced Fed
Drives: FS-T
Re: 91 Galant VR4
^ Have you not read this thread at all lol? I can't speak for John but I highly doubt he is building a tube chassis front end GVR4 with an air-to-water intercooler to race the local Mustangs on 94. Nor will a 16g ever be put on this car...
Old 12-21-2009   #128
Re: 91 Galant VR4
^Pretty sure that its going to see some runs against local mustangs.
Infact thats a sure bet.
Old 12-21-2009   #129
Re: 91 Galant VR4
Yes the intent of the build is to take the #1 slot for the gvr4's. Street racing, not so much anymore but I do plan to show up at porky's and other local events with it. And no on the 16g, nothing smaller the GT4202.
And the update: front end is almost all finish welded, I need to drop the front sub frame to do the rest. And most of the inside is finish welded also, I have about 2 more hours of welding then its on to dash and filling holes.
Old 12-21-2009   #130
rocket2g
Drives: 2g
Re: 91 Galant VR4
great. get out there. show everyone whats up. great build. alot of money in this.
rocket2g is offline   Reply With Quote
Old 12-21-2009   #131
Re: 91 Galant VR4
Yes a lot of cash, and a lot of my time also. Thanks for looking, off to the garage for more finish welding.
Old 12-21-2009   #132
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: 91 Galant VR4
just out of curiousity, how did you figure out what angles to mount the struts at?
Style's automotive engineer
Old 12-21-2009   #133
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Re: 91 Galant VR4
A few pages back there is a pic of the car missing the front end and a weired looking tube and plate structure. The tube an plate structure was made BEFORE the front of the car was removed and the new front built to it.
Edit: this pic
Old 12-21-2009   #134
s1ngletracker
Drives: A BMW
Re: 91 Galant VR4
ah, so he used that frame to preserve the original angles. Nice, thanks Ryan.
Old 01-03-2010   #135
Re: 91 Galant VR4
Now the hole cage, front end structure is finish welded and gussets added where needed. We made a new mount for the steering wheel. And finished up the strut mounts. I have made the mounts for the engine dyno but a project at work has taken up the engine dyno for a few weeks so I still need to make the bell housing and run coolant hoses. I also finished up the exhaust manifold and intake manifolds, now I just need to flatten the head flanges and they will be good to bolt on. I will snap a few picks of the progress in the next few days. On the intake manifold I welded some big bungs to the bottom portion of the runners close to the plenum, then drilled 2 injector holes next to each other at an angle. So the 8 1600's will be my secondary's and the AEM will think they are 3200cc injectors with an external injector driver box. Then I will use a set of smaller injectors at the stock location for idle and low throttle.
Old 01-03-2010   #136
s1ngletracker
Drives: A BMW
Re: 91 Galant VR4
where do you work?
Old 01-03-2010   #137
Re: 91 Galant VR4
HiTech Motorsport in Elk River.
Old 01-03-2010   #138
Re: 91 Galant VR4
Thats an assload of fuel.
Old 01-03-2010   #139
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: 91 Galant VR4
Word lol
Old 01-03-2010   #140
Re: 91 Galant VR4
Cot damn, thats a lot of injector. What kind of fuel pump setup are you planning on running?
