Old 03-08-2010   #81
way2fastalon
IS Broken :-/
way2fastalon's Avatar
Re: 1991 talon 500 hp project
engine and trans are in the car should be running today
1991 Eagle Talon awd
2.0 fully built lower-end
+more mods to list
Old 03-09-2010   #82
way2fastalon
IS Broken :-/
Re: 1991 talon IS ALIVE
on 03/08/10 at 8:04 pm it started up with a morning moan and then growl
i have a video will post .
1 issue tho
oil pressure is low im thinking oil pump is bad it sits on L at idle then when its brought up to about 3000 rpm it gets to the start L operation range and tops out there i have a manual oil pressure Gage but its not hooked up due to the turbo using that hook up.
+more mods to list
Old 03-09-2010   #83
Connect the aftermarket gauge in the spot that the factory gauge goes in. Having an aftermarket gauge is much more useful than the crap stock gauge.
Old 03-10-2010   #84
way2fastalon
IS Broken :-/
Re: 1991 talon 500 hp Video posted
http://www.youtube.com/watch?v=NrXfATjSj5E
there are 2 videos this is the 2nd video
+more mods to list
Old 03-17-2010   #85
way2fastalon
IS Broken :-/
got my fp red today ....!! going to put it on this weekend ...
+more mods to list
Old 06-03-2010   #86
way2fastalon
IS Broken :-/
jees
so here is the update car runs great no dyno or tune yet need a few more spendy parts
+more mods to list
Old 06-03-2010   #87
What, you're not making 500awhp yet?!
Old 06-03-2010   #88
^I once farted 500awhp on a DJ, it burned afterward. I think it left a mark.
That was my only mod oh and another brown person in my car.
Old 09-28-2010   #89
way2fastalon
IS Broken :-/
dont look like im going to make it do the dyno anytime soon ... i need a better trans and my turbo needs to be finnished been a good car till i got the turbo smoke
Old 10-13-2010   #90
way2fastalon
IS Broken :-/
turbo is back together going to feed from the head this time
i am looking for a differnt one id trade for a sc6152 or a hx35 with a bep
+more mods to list
Old 10-14-2010   #91
way2fastalon
IS Broken :-/
i started polishing my turbo bored as hell ..
Name:	turbo un polished.jpg
Old 10-14-2010   #92
I still have that manifold for you. Also the HXs aren't all that great I had one.
Old 10-16-2010   #93
way2fastalon
IS Broken :-/
Question Re: 1991 talon 500 hp project
i made some progress tucking wires and cleaning up the engine bay got the turbo back on and it dont smoke so thats good i changed the oil feed line to the head changed the oil drain to high temp silicone hose all i got till i can get the braided line got my cooling fan back in pulled the ac out
what dose it mean when you have the front of the car up in the air and you can spin 1 tire and the other tire dont spin right away takes about 4-5 turns for it to catch then the other tire it spins the opposite direction im trying to pinpoint what is bad the viscous or the center diff or both ?
+more mods to list
Old 10-19-2010   #94
way2fastalon
IS Broken :-/
Wink Re: 1991 talon pics added
still working on tucking stuff away going to move the batt to the back
wile im doing that im doing the fuel pump rewire for wire im using old jumper cables that are 4 gauge
i tryed hiding the tb cable and cruse control box but the throddle cable hung up where ever i put it but stock location i have a polished valve cover going on soon here i still have some sanding to do yet
Old 12-18-2010   #95
way2fastalon
IS Broken :-/
well after figuring some things out i found that had a weak oil pump after all so i just acquired an hx40 from my brother needs to be cleaned up getting a bep housing and calling it a day
so plans for after x-mas are to pull the old oil pump out put a newer one in that i know is good get the hx 40 down to the turbo shop to be cleaned up and ready for use
+more mods to list
Old 01-19-2011   #96
way2fastalon
IS Broken :-/
hx was junk bought a 14b got it running great going to get tuned at map on Tuesday 25th at noon !!!!! im hoping for 280 awhp PLEASE GOD !!!
Im also getting it ready for the cross country trip with it since i am moving to California im going over every little thing with it when i had it up in the air i seen some things i could replace the rubber bushings/ bering inside rear main the axle going to the rear diff are bad there cracked and move alot fixing every little oil leak i find sick of smelling it
replacing the timing belt it stretched funny so im doing the kit here i dont know if gates do warranty's on there blue belts ?
still trying to figure out why the wheel shakes back in forth left to right wile going 40-80
+more mods to list
Old 01-19-2011   #97
280 on a 14b? Haha good luck.
Old 01-19-2011   #98
way2fastalon
IS Broken :-/
the intercooler piping and charge pipe are next to get fixed
+more mods to list
Old 01-19-2011   #99
There are like 73 couplers in that engine bay lol
Old 01-25-2011   #100
way2fastalon
IS Broken :-/
Talking 1991 talon 230 hp project
well today i got tuned i have a video here
found out i have some boost leaks and few other things that need help and will re dyno in california
http://www.youtube.com/watch?v=JWQQ05HUIYQ
+more mods to list
