Old 04-27-2010   #301
Re: 91 Galant VR4
I've never been on his nuts lol.
Old 04-30-2010   #302
URV8SUX
URV8SUX's Avatar
Re: 91 Galant VR4
Keep up the good work John get this thing going!
Old 05-02-2010   #303
Re: 91 Galant VR4
Cash money is about all I need to finish this build. Here are the update pics, and this will be it for a while. I will be storing the car for a few months, just until I have the cash to finish the project, then it will be reassemble with some minor touch up here and there.
Here is the flat black dash.
I added a 1/4" thick aluminum washer to the rear cross member mount plates.
Here is the down pipe and twin tial 38mm waist gates plumed back into the exhaust, the other one will be mounted over the alternator.
Here is the almost completed engine bay shot.
I added aluminum hold down/together straps for the water to air intercooler.
Old 05-02-2010   #304
Re: 91 Galant VR4
Crazy hot! Can't wait to see this thing rollin
Old 05-02-2010   #305
Re: 91 Galant VR4
Gawd Ver. 2.oh no is looking great.
Keep up the hard work a lot of people are happy for you and excited to see this on the road.
Old 06-23-2010   #306
Re: 91 Galant VR4
The car runs, it would have fired right up but I forgot to mark which coil was what, so after 10min of poking it starts and cams at 1400rpm on E-85 with an old map I had converted to 550cc primary injectors and E-85.
Now for the bad news, to make a long story short I was trying to get the car on the dyno and up to the MAP shoot out this weekend. But the Evo 3 3rd and 4th gears I bought for the home made Stage 4 tranny are on national back order and I will not have them for a few weeks.
I would ask to buy or borrow a tranny or just the gears from a tranny but I think I can wait a little longer for my parts to show up. So for now here is a small look at what we have been up to for the past 2 months.
Here is a run down of the new shinny parts:
- Tranny, everything to make a stage 4 tranny: evo 3 1st gear, cut double syncro 2nd, evo 3 3rd and 4th gear conversion, new bearings threw out, welded center diff, welded parts on the front diff you help keep it in 1 piece, new shift forks, new magnetic drain plugs, new throw out fork and throw out bearing, etc
- Quarter master twin disk clutch
- Tial 38mm WG with 1.6bar springs x2
-Tial 50mm bov
-A1000 fuel pump, filters, and FPR
-PTE 550s primary and ford 1600cc secondary injectors
-civic 1/2 sized radiator
-17" wide Kirkey race seat and 5 point harness for the passanger side
-A ton of electrical stuff to make everything work
-BF goodrich T/A drag radials 225 50 15's this should give me a 9.2" contact patch at all 4 corners
-etc
So I hope to get it down the track this season yet, but as the title goes on the galantvr4.org post, the never ending project.
Old 06-23-2010   #307
Re: 91 Galant VR4
Looks great!!! Interesting how you mounted the coils.
Old 06-23-2010   #308
Re: 91 Galant VR4
Is this what you called about?! What can I do to help?
Old 06-23-2010   #309
santa
Boost Spike
santa's Avatar
Re: 91 Galant VR4
How come the wastegate's are not at the collector?
Old 06-23-2010   #310
Re: 91 Galant VR4
It's a divided housing, but yeah, I guess it would still be doable down there.
Old 06-23-2010   #311
Shotgun!
Totenritt
Shotgun!'s Avatar
Re: 91 Galant VR4
Best of luck with the finishing touches! It really sucks that those tranny parts didn't show in time, I was moving things around to be able to make it the the MAP event and see this run.
Old 06-23-2010   #312
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: 91 Galant VR4
I haven't looked at this thread in a while and WOW, crazy to see the progress!! Keep up the good work!
Old 06-23-2010   #313
DSM_brother2
Drives: to the shop
Re: 91 Galant VR4
that thing looks amazing!!!! good work
93 talon tsi/ 6 bolt swap
Mitch
Old 06-23-2010   #314
santa
Boost Spike
santa's Avatar
Re: 91 Galant VR4
I know its divided. I've never seen anyone place gates like that. I've always saw them at the collector.
Old 06-23-2010   #315
Re: 91 Galant VR4
Looks fantastic.
Old 06-24-2010   #316
Re: 91 Galant VR4
When I made the manifold I was not looking at cutting the front of the car off. So at the time that was the only place they would fit. If I can get the boost down to 28psi with out much creep I will be ok.
Old 07-03-2010   #317
Re: 91 Galant VR4
My gears shipped last friday, and I received them Wednesday this week. So here is the update, not much left then its off to the dyno and the track to see what this thing can do at "low" power.
Thanks for looking
Old 07-03-2010   #318
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: 91 Galant VR4
Looking very good so far John. Very impressive.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 07-03-2010   #319
blackawdtsi
Drives: 2G DSM
Re: 91 Galant VR4
Are you going to countersink the inner bolts for the QM or grind down your shift fork?
Old 07-03-2010   #320
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: 91 Galant VR4
Wow man I would have to say that this thing has come so far since I seen it at LSE. Great job man!
Amsoil Dealer
