Old 11-19-2010   #1661
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Evo X upgrades
You dropped in new pistons/rings without running a hone or anything? I'd definately say there's a chance that could be the root cause there. The rings may have never bedded in well and hense the increased blow-by.
Pop the head off, oil pan off, remove pistons and rods and run a quick hone up and down. Re-ring and see if that helps. Alothough I don't know Evo X's so I have no clue how difficult removing the head and oil pan is compared to a dsm.
Not easy at all.
Old 11-19-2010   #1662
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Shane didn't want to hone it in the car, said we'd have to pull the motor and that's what led us to where we're at. I'm not a mechanic and I can't afford to have that kind of work re-done. I assume it'd be over $3k to pull the motor to do that right.
Even at Amsoil's $11/qt that will buy a lot of oil.
Old 11-19-2010   #1663
simulatedwood
Drives: 08 Evolution X
Re: Evo X upgrades
Id say before jumping to conclusions, Do the necessary troubleshooting steps then worry about whats next.
If the car runs good, just let r buck, enjoy this thing!
Old 11-19-2010   #1664
Re: Evo X upgrades
$4.40/qt Mobil 1 FTW
Old 11-19-2010   #1665
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I'm not worried, I'm just saying the rings are staying in the motor unless it stops running right.
Old 11-19-2010   #1666
Re: Evo X upgrades
Not easy at all.
Just curious, what makes it so difficult in comparison to say a DSM or Evo 8?
And while I agree that yes the ideal way would be to have the motor out, does that mean it has to be done that way? I did the one cylinder on my talon with the motor in the car. I had a bunch of rags/blankets under that cylinder, around the crank, to catch as many particles as possible. Then wiped down the cylinder walls as best I could with rags and tranny fluid and wd40. Never had an issue. Shane when you did the pistons in your 2G, those were just drop in correct? Did you remove the motor for that?
Just a thought, to each their own
Old 11-19-2010   #1667
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
I am sure Shane could answer this best. Basically every time we talk about the 8/9 vs the X he says how much more work the X is to do. I haven't done it personally so I couldn't tell you.
Old 11-19-2010   #1668
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
What he had said to me is that if it were his car he'd turn the motor upside down on an engine stand and hone it but he wouldn't do that on a customer's car.
Old 11-19-2010   #1669
Re: Evo X upgrades
Whenever I hone a block, I pull it out and apart to make sure nothing gets in there. It makes a huge mess when you ball hone a block. I am not comfortable doing that in car on a customer car, it doesn't take much metal to screw up things.
Old 11-21-2010   #1670
428gt
Re: Evo X upgrades
...and a spun bearing down the road
428gt is offline   Reply With Quote
Old 11-21-2010   #1671
Re: Evo X upgrades
Not easy at all. About the same amount of work as on a DSM.
FTFY.
Old 11-22-2010   #1672
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
FTFY.
I haven't done either, was simply relaying what others who have performed the work have said. You have now done that, so I defer to your expertise
Old 11-22-2010   #1673
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Planning to bring the intake to Primo tonight. I'm going to have them weld an AN fitting on it for a return from my catch can.
Old 11-23-2010   #1674
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I was doing a lot of reading on crankcase ventilation today.
I'm probably wasting my time trying to make the stock setup work--it is only a single fitting that couldn't be more than 3/8ths. It sounds like most setups are running two to four large AN connections (AN10+). Four is obviously overkill but I won't get much ventilation with the stock setup.
I did learn a fair bit. The can on the front of the motor (PCV to intake manifold) collects the most oil but is apparently not the important can for ventilation...the back one is.
For now I'm going to get a fitting on my intake for that connection and see if it does anything. My suspicion is that I'm going to have to pull the valve cover and have some large fittings welded in, along with a different catch can.
Old 12-15-2010   #1675
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Went to drive the Evo to Sensers tonight. The car dies every time that I let the clutch out. Doesn't move at all. I fear that something expensive happened to the drivetrain on my venture into the snow on Saturday. Guess I'll try warming it all the way up tomorrow night and try again. FML
The beater works and the Blue Moon is cold.
Old 12-15-2010   #1676
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
That doesn't sound good at all. Hopefully its nothing serious.
Old 12-15-2010   #1677
Re: Evo X upgrades
Does it idle ok?
Old 12-15-2010   #1678
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Does it idle ok?
It starts and runs fine. I revved it a few times and it felt like the car was cold but responding normally. I tried it three times in reverse and once forward. It didn't move at all, it just conked out.
Nothing seemed unusual when I parked it. I'll try it again on Thursday night...bring a flashlight out to the garage and see if I can see anything (like a puddle of fluid!).
Old 12-15-2010   #1679
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
Was your parking brake on?
Also I have had parking brakes ice up and stick to rotors before. Perhaps that is what happened and you need to jar the ice loose.
Old 12-15-2010   #1680
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
Re: Evo X upgrades
^ +1 on that ive had it happen a few times to me. ive also made the facepalm mistake of leaving the hand brake up.
341hp/344tq E-85 FTW
Shane Tune@ DB
