Old 03-24-2011   #441
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Sweet powah Kracka, very impressive.
I kinda agree with lomker though, are you sure its not injectors? ETS said they ran the stock fuel pump out at 420whp on their 35 kit.
Old 03-24-2011   #442
Rmondoh
Minority of MitsuStyle
Rmondoh's Avatar
Drives: '08 OBP Evo X GSR SSS (Deadmau5X)
Send a message via AIM to Rmondoh Send a message via MSN to Rmondoh Send a message via Yahoo to Rmondoh
From what Kracka told me yesterday, I think he said the IDC was at 93%. So they should still be good with the setup, but I'll let him chime in and post.
08 Evo X GSR - Octane Blue Pearl
Cobb Stg1 AMS 93 OTS: 305hp 291tq 20.6psi
Cobb Stg1 93 Pro: 317hp 322tq 24.5psi
Cobb Stg2 AMS 93 OTS: 315hp 323tq 23psi (LWG map)
Cobb Stg2 93 Pro: 343hp 358tq 26psi
Cobb Stg2 93 Pro: 355hp 361tq 26.4psi (ported stuff)
Rmondoh is offline   Reply With Quote
Old 03-24-2011   #443
That's kinda weird, since Scheides put down ~400 at DB with a stock fuel pump. This dyno reads closer to MAP's dyno as far as local dyno's so it seems. I guess I would think injectors before pump as well, but I guess we'll see.
Old 03-24-2011   #444
Scheides also has DW800cc fuel injectors so it's not apples to apples. I think adding injectors or a pump would accomplish the same thing, but the guys at Cobb said the actual problem on my car is the pump since IDC's are at 93%.
Old 03-24-2011   #445
Badass numbers dude! So easy to forget the stock turbo on the X is smaller than the 8/9 but these numbers are fantastic! Super vague ricer math puts you somewhere around 315whp/330wtq at DB I think? Numbers to rival gheyrod (the 9) to be sure!
You're totally right about the injector/pump thing. As I have learned from Shane, you can push a fuel pump further with bigger injectors, which is basically what I did on my car. ~380whp is the limit w/ 800's and it looks like its around 320whp w/ stock 600cc injectors. It's all about having more resolution with which to store up fuel and spit it out at the particular cylinder. Bigger injectors can dump larger amounts of fuel in shorter bursts, allowing the fuel pump to be pushed further. At this point (for both of us) an upgraded fuel pump and keeping the existing injectors is the perfect plan--won't have to mess with injector scaling/latancies and you'll just have plenty of fueling headroom on top. Plus, if you upgrade turbo or switch to e85 later, you're set with just an injector upgrade.
Go gheyrodX go!
Old 03-24-2011   #446
Keep in mind my IX made 326 @ DB then put down 360 @ Cobb with a very similar tune (converted to SD, but AFR, timing, and boost was kept steady). Everyone must also keep in mind that the VIII and IX pumps also needed replacing before the stock fuel injectors did. Along with the X's larger stock fuel injectors it also got a more capable pump so the stock fuel system is able to support more, but still not enough.
This trying to compare dynos is retarded though, it just can't accurately be done. DB's dyno reads what DB's dyno does and Cobb's dyno reads what Cobb's dyno does.
Moral of the story, my X is making damn impressive power for a stock turbo/pump gas X on Cobb's dyno and the stock fuel system isn't able to supply what my car is now capable of. Getting back to the original intent of this testing...the ported manifolds and throttle body made damn impressive gains!
Old 03-31-2011   #447
Thanks to Scheides being awesome and mailing me his Cobb fuel pump install kit (they're still back-ordered) I'm able to get my tune finished today
Old 03-31-2011   #448
DSM_421
So how much does it cost you to get tuned every time, or do they hook it up? I feel like you are getting new t00ns every day
Old 03-31-2011   #449
They hook me up pretty good.
Old 03-31-2011   #450
Murlo26
Murlo26's Avatar
It's to pay him back for promoting the AP on EvoM
Oh and apparently sending mailers out...I'll get you back somehow
Old 03-31-2011   #451
LOL figured you'd want some bathroom reading material!
Old 03-31-2011   #452
Murlo26
Murlo26's Avatar
I was so damn confused...like, how did they find me!?
Oh, that went right in the garbage haha.
Old 03-31-2011   #453
Fuel pump did the trick! IDC's around 89% with nice steady AFR's
Old 03-31-2011   #454
Murlo26
Murlo26's Avatar
Results!?
Old 03-31-2011   #455
Still on the dyno, will post #'s as soon as it's done.
Old 03-31-2011   #456
cmspaz
Walls need hugs too
cmspaz's Avatar
I wasn't even on the dyno that long, hurry up.
Originally Posted by Trogdor
Old 03-31-2011   #457
Numbers pretty much remained unchanged with the fuel pump...the setup was pretty maxed at that point I guess! I am fine with the fuel pump being just a little extra safety margin though since it was right on the edge and inconsistent as the fuel temps increased before.
Old 03-31-2011   #458
cmspaz
Walls need hugs too
cmspaz's Avatar
Time for a BBX?
Old 03-31-2011   #459
Hughes is STS fo lyfe son.
Old 03-31-2011   #460
Time for a BBX?
Nope, really happy as it sits! If I did anything it would be a BBXLite.
