Old 04-05-2011   #361
Re: Project Lex
Looking sweet dude!
Old 04-05-2011   #362
Re: Project Lex
^^The one you've had sitting there for like 6 years? lol
I have only had the SC300 intake manifold for a year or so and I have given up on that project. It's the one on this page: http://fsmoto.net/products.html
Old 04-05-2011   #363
Re: Project Lex
Is it flanged for a 100mm TB or larger?
Old 04-05-2011   #364
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Re: Project Lex
LOL at the sites moto "we'll make your Sh*t f*cking ridiculous"
Old 04-05-2011   #365
Re: Project Lex
Didn't get a whole lot done. What I discovered is it appears to be impossible to completely remove the lower oil pan without either removing the engine, or removing this big arse cross-member. I needed about another 1/4" but couldn't jack the motor up any further to get that extra little bit. Oh well.
I was however able to just drop it as far as it will drop, and can slide some newspaper in there. You can see where I circled, that's where I need to drill for the oil drain line. So the newspaper should catch almost all of the metal flakes from getting into the lower oil pan.
Now just need to get a right angle drill, a Uni-bit, and that should take care of that.
ID:	11443   Click image for larger version
Old 04-25-2011   #366
Re: Project Lex
Well I've been stuck in Naw'lens for the past few weeks so haven't been able to make much progress. But with the extra money I'm making, decided to spend a little bit on a turbo blanket to keep things as cool as possible. Very excite!
$85 shipped
http://cgi.ebay.com/ebaymotors/ws/eB...m=300434923446
Old 04-26-2011   #367
polishmafia
Smells like cat poop
polishmafia's Avatar
Re: Project Lex
Just read back and got caught up. Awesome progress!
Old 04-26-2011   #368
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Re: Project Lex
Git that thing goin!
'04 Honda Ricer: stock
Old 04-26-2011   #369
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: Project Lex
$85 shipped
Good choice!
Amsoil Dealer
Old 04-27-2011   #370
Re: Project Lex
Got home from Naw'lens today.
Went to MAPerformance and picked up a couple things as well. As always, thanks for the great prices guys!
Turbosmart Compgate 40mm:
Oil Feedline Kit:
Also had some parts waiting for me in the mail. Time to get some work done!!
Ebay Gasket kit:
2 used ignitors from Ebay (one to replaced my burnt one, and one for a spare):
ID:	11533   Click image for larger version
ID:	11534   Click image for larger version
Old 05-04-2011   #371
Re: Project Lex
Not too much to update. But I've gotten the oil drain hole drilled out with a 7/8" hole saw. And the two bolt holes are tapped (M6x1.0).
Here's some pics:
Drilling the hole
Hole drilled:
Cleaning with Brake Cleaner:
Holes tapped and cleaned:
ID:	11571   Click image for larger version
ID:	11572   Click image for larger version
ID:	11574   Click image for larger version
ID:	11575   Click image for larger version
ID:	11577   Click image for larger version
Old 05-04-2011   #372
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: Project Lex
How do you clean the shavings that may have got into the oil pan?
Amsoil Dealer
Old 05-04-2011   #373
Re: Project Lex
Lower and Upper oil pan? I'm confizzled.
I think some of the poopra guys use stock 3000GT ignitors as an upgrade also don't they?
Old 05-04-2011   #374
Re: Project Lex
I dropped the lower oil pan and put that newspaper that you see in the pics there to catch the shavings. Apparently some people do it without dropping the pan at all. I didn't want to risk that so that's why I dropped the lower pan so I could catch the shavings on that newspaper.
As for ignitors, yeah I'll cross that road when I ditch the stock distributor. For now I'm keeping the distributor. Try to do things 1 by 1 as much as I can to make troubleshooting as simple as possible.
Old 05-04-2011   #375
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: Project Lex
Good call, looking good.
Amsoil Dealer
Old 05-09-2011   #376
Re: Project Lex
Drilled the oil filter union bolt to accept a 1/8npt fitting for my oil feed. You can either buy one for an IS300 for like $25 and it's already tapped, or just drill the stocker. And well, considering I already had a 1/8npt tap, and access to free drill bits and a drill press, that was an easy choice
Lots o lube:
Pilot drilled:
Hole drilled using "R" size drill bit, and de-burred:
Tapped for 1/8npt. Wish I coulda tapped further but it was getting HARD. That look good enough to you guys?:
1/8npt to -3AN fitting installed. Used some liquid pipe thread sealing compound on it:
OFH installed back on the car, badda bing:
Also installed the drain fitting. Need a gasket for that thing yet...
ID:	11598   Click image for larger version
ID:	11599   Click image for larger version
ID:	11601   Click image for larger version
ID:	11602   Click image for larger version
ID:	11604   Click image for larger version
ID:	11605   Click image for larger version
Old 05-09-2011   #377
Nartanian
I will eat you aliiiive!!
Nartanian's Avatar
Drives: 1992 Galant VR-4
Re: Project Lex
Nice progress.
Just some corn and a MBC. Try it. You'll be amazed.
Nartanian is offline   Reply With Quote
Old 05-09-2011   #378
Fran05
Drives: DSM
Re: Project Lex
Very nice! Keep us updated please
Old 05-09-2011   #379
Re: Project Lex
Nice work on that bolt! Always nice to save some money and get your hands dirty at the same time!
Old 05-09-2011   #380
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: Project Lex
Nice. Good job and keep it going.
Amsoil Dealer
