Old 08-17-2011   #521
Re: Project Lex
Oh snaps! Good luck!
Old 08-17-2011   #522
Re: Project Lex
Wah-hoo!
Old 08-18-2011   #523
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: Project Lex
You just couldn't stay away, could you?
Welcome to the fun side!
Originally Posted by Trogdor
Old 08-18-2011   #524
Re: Project Lex
Holiday in MG? dang. E85ish FTW.
Old 08-18-2011   #525
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Project Lex
Hey thats my E85 pump Same holiday I use typically on Central there.
Grats! I need to stop by and see your car when I get back in town.
Old 08-18-2011   #526
Re: Project Lex
^Your pump my ass, you don't even use it! lol.
Good luck B.
Old 08-19-2011   #527
Re: Project Lex
http://www.youtube.com/watch?v=59L06JGwnrc&hd=1
Old 08-19-2011   #528
Re: Project Lex
Ballllin!! Love the video haha. Gotta have nav, and some nakka beats.
Old 08-19-2011   #529
Re: Project Lex
Green for tha moneys, Nav for tha honeys.
Old 08-19-2011   #530
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: Project Lex
Lookin sweet man I'm also diggin the navigation and music. Nice little round about
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 08-19-2011   #531
Re: Project Lex
Nice! How does it feel, rippin around in it? Can't wait for a ride in this thing.
Old 08-19-2011   #532
Murlo26
Murlo26's Avatar
Re: Project Lex
Looks like fun for sure!
Old 08-20-2011   #533
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: Project Lex
Nice !!
Amsoil Dealer
Old 08-20-2011   #534
Re: Project Lex
No wheel spin in 3rd no care. Haha jk, Nice progress! It's nice to see this is up and running, now get it tuned!
Old 08-30-2011   #535
Re: Project Lex
Brief update:
Installed new Dist Cap and rotor for good measure, and because they are cheap
New IS300 ignition setup has arrived (to be installed this winter)
Raw materials from Discount Steel to make my own intake manifold this winter because I refuse to pay $800+ for just a plenum
Yesterday
Big thanks to Shane at DB Performance for the dyno time. Never made a clean pass due to misfires above 8psi. Also found I made a mistake hooking up my wastegate. So because of those two problems I went home with a small TO-DO list, and a couple spare parts from Shane's SC300. I fixed my WG issue. And using Shane's parts, troubleshot my misfire problem to the coil, must be old and degraded. Luckily I had a spare Junkyard coil in the garage. Turns out it works like a champ. Car is boosting at about 10-12psi right now, AFR's in the 11's, but I'm going to stay out of boost for the most part until I can get back on the dyno, which should be next week.
Junkyard spare coil installed:
Pile O Troubleshooting parts, thanks again Shane
Old 08-30-2011   #536
Murlo26
Murlo26's Avatar
Re: Project Lex
Nice! Awesome update...keep it up. Can't wait to see some numbers. Glad its coming together man.
Old 08-31-2011   #537
Re: Project Lex
Woot and toot! Cant wait to see some numbas.
Old 08-31-2011   #538
Re: Project Lex
Yeah, a whole 250hp @ 10psi probably... LOLz
Old 08-31-2011   #539
Re: Project Lex
green bean makes a lot more than 250, i'd say 350/350.
Car feels fucking awesome and all the sounds are overwhelming. It's definitely moving a lot of car and it moves it well.
I can't wait to see what it does after the tune.
Old 08-31-2011   #540
Re: Project Lex
Cool thanks man, glad you like it. I do love how loud the turbo is, and the exhaust tone of this car. Just need to recirc my wastegate dump, not a fan of the loud annoying blahhhh. Drowns out the much better sounds like the turbo and sexay exhaust tone. I have some flex exhaust tubing on the way. And thanks for hooking me up with those small straight sections that I can use, it'll be perfect for what I'm planning I think.
Car is still running like a champ. So I'm not going to touch a thing until dyno day. So for the time being, started planning some misc stuff. Since I'll be making my own Intake Mani, I was thinking about what to do for vacuum ports on it. So made this crude drawing showing the simplest and cleanest way to run to run these lines. It involves using a couple Tee's which I'm not 100% a fan of, but seems like it would end up being the cleanest and simplest way of doing things, because some of them it means I only have to run one line and the 2 components are somewhat close to each other so then I just Tee it right near the components, rather than running 2 separate lines. Just a little simpler and cleaner. And where I use a Tee, I use a larger line feeding the Tee which is 2 smaller lines to hopefully reduce any issues with pressure loss or whatever could be caused from running a Tee.
But, interested to hear other peoples thoughts...
