Old 11-15-2011   #41
Re: after 10 years its coming back to life
picked up a head gasket from spaz yesterday and got the head on. Also clocked the evo 3 turbo and had to cut the bolt out of the o2 housing since I could not get both nuts on the bolts with the down pipe on. Just used a new bolt since the flange was slotted to start with and was able to use the stock nuts to bolt it all up with the help of spaz.
It is the first time in 10 years the car has had a full engine and tranny in it It is getting closer
Old 11-15-2011   #42
Looking good. I have to pull my visors apart as well when I put in a suede headliner in the GSX this winter.
Old 11-15-2011   #43
cmspaz
Walls need hugs too
cmspaz's Avatar
If by "with the help of spaz" you mean I held a wrench on a bolt that wasn't spinning anyway, then yes, I helped.
Originally Posted by Trogdor
Old 11-15-2011   #44
Sparky2211
Sparky2211's Avatar
Drives: 2g DSM, 2008 Evo X
Looks good so far!
1997 Eclipse GSX - Project car - 601hp/475tq
2008 Evo X GSR SSS - Daily Driver - 407hp/434tq
Sparky2211 is offline   Reply With Quote
Old 11-17-2011   #45
It is getting cold out now. I worked on it a little bit today. got the a/c pump on,alt on, put power steering back in the car. also rebuilt the tial waste gate and made a j pipe.
Old 11-17-2011   #46
Nice, your 16G is facing the wrong way. lol
Old 11-17-2011   #47
yes it is facing the wrong way now, but looks a lot better with out a big j-pipe and the stock wastegate on it
Old 11-17-2011   #48
portum89
portum89's Avatar
i think i saw this whole project live lol
95 talon tsi awd...pte scm 5031 /950ccs on corn / gsc s1's / comp stage 4 / 12.8 @113mph - SOLD
99 Spyder GS-T 16g / 264's / 550ccs / Reflash OWN
Old 11-18-2011   #49
Dad came by today and we put the timing belt on the car. Also put the cas and rail/injectors on to seal the rest of the engine up till I get a intake manifold. and got the lower piping all hooked up
also put the winter tires and rims on the hatch so it is ready to go now
Old 12-06-2011   #50
Been working out in the cold the last 2 days. I got a new rear bumper on the car now I found at the junk yard. it has no holes in it like the old one. It was cheaper to buy this one over me fixing the old one on the car. also picked up a heat shield for 5.00 local. The evo 3 intake manifold and coil bracket showed up picked it up for 75.00 shipped since I sold the 2 that I had years ago.
What I got done. timing cover is on all pullys and belts are on the car. got the oil cooler mounted and -an lines on the ofh to the oil cooler. Got the evo 3 intake on, all the wiring is on. Just have to make the harness for the 94 cas.
Old 12-06-2011   #51
Holy shi-yeet! So close, keep going man!
Old 12-06-2011   #52
Looks good! It'll be ready to go in no time!
Old 12-06-2011   #53
I am almost down to what I can do with out buying parts to get it all the way done. I cant wait to get it running it had been a long 10 years of it sitting
Old 12-07-2011   #54
made the 2g to 1g harness today
Old 12-07-2011   #55
Progress is good!
Old 12-07-2011   #56
thanks Chris. It is on its way to the spring cruise
just got done baking the head lights took out the amber turn lights. heated in the over @ 350 for 15min. With them that warm I was able to pull them apart and put them back together with the glue still hot to get them to seal back up.
Old 12-07-2011   #57
^^What kinda beer ya drinkin there?
Old 12-07-2011   #58
the very last glass of nordeast out of the 16gal keg
Old 12-11-2011   #59
I got the head light's in. the wire is broken some were for the pass side low beam. Other wise all the other lights work.
Also when to radio shack and picked up 2 8ohm 20watt resistors to go in line to get the rear turn signals to work right and rewired the brake lights,reverse lights to work with the talon tails just like they do on the talon from the factory. I got out all the trunk panels out and back in the car. I just have to cut the top off the sub box that is fiber glassed in and make a new floor so I will have a box to store stuff in also.
Old 12-12-2011   #60
made a battery tray today
