View Poll Results: Where do I go from here? (now that all of the children have grown up...)
Build the X 17 56.67%
No one wants a $60k evo with high monthly payments, get out now and buy a 9. 13 43.33%
Voters: 30. You may not vote on this poll
Old 06-14-2012   #2221
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Here just went and took a picture
From looking at this I assume these are barbed.
Old 06-14-2012   #2222
Yea, and that's not much room to work with. Good luck with the fuel issues, I thought most pumps had check valves built into them?
Old 06-14-2012   #2223
Murlo26
Murlo26's Avatar
Nah in boost I don't have an issue, my car has run over 80psi no problem at full boost.
Its at idle where the issue is, low load in general, before the 2nd pump kicks on. When the second pump runs, there isn't an issue.
I know, its not much room at all, not sure what to do now. I am not sure how big the check valves are, so I dunno.
I think the wally 255's do have a check valve built in. But the pump I am using from blaqops is like a GT500 pump or something strange.
Old 06-15-2012   #2224
Murlo26
Murlo26's Avatar
Bought this...
http://www.jegs.com/i/JEGS+Performan...50011/10002/-1
And two of these...
http://www.jegs.com/i/JEGS+Performan...00845/10002/-1
They will be here in the morning. Can't afford to lose two days if I want to make PG, saturday delivery ouch! But MUST FIX EVO!
Normally I do all black/boring stuff as I like stock appearing shit, but they were out of stock until july, so I went balla blue
Old 06-15-2012   #2225
Tachyon
Tachyon's Avatar
Drives: Icarus
Nice! Overnight parts, from Japan*
*'merica!
-Sebastian Vettel
Old 06-18-2012   #2226
Murlo26
Murlo26's Avatar
I am officially throwing in the towel.... (edit: for PG only, not the evo in full haha)
I had to do some work (as in work, not car work lol) over the weekend and that coupled with fathers day = no time for car work.
Also I was going to take friday off and next monday to prepare for proving grounds and recover That got axed as work is INSANE right now. So my tune is just not ready at all and neither is the car mechanically and this week just isn't going to give me a ton of time to finish it off.
So I am not about to try and rush the car and go to PG to beat the piss out of it with a tune that isn't really ready, just ain't happening. As much as I would love to go, I want my first track experience to be fun and not filled with agony and a tow home.
Good luck everyone else though I will be heading to slippery falls in the coming weeks though.
Old 06-18-2012   #2227
Good decision, but what do you need to do?
I thought it was good to go on pump gas?
Old 06-18-2012   #2228
Murlo26
Murlo26's Avatar
No, we had to make tuning changes to lower load as I was hitting 330 load at 24psi on pump gas. So we had to do injector and MAF rescaling then it still was hitting too high of load so we were going to do some more rescaling and also raise base idle pressure to add fuel and in turn reduce load further.
Our goal was to have load be around 275 on pump gas where I was so we have room on it for when I do the E85 tune.
Why do we need to lower load you might ask, well there is a hard coded load cap at 360 in the ECU, so you cannot go higher, so we are trying to make sure we don't hit that.
So when we tried raising base pressure is when we found an issue with something (not sure yet) and realized pressure wasn't increasing enough. So until I figure out the fuel pressure problem and get a full retune on pump I wouldn't be ready.
In theory I could revert to my old setup that I had last week and refine that tune a bit, but I don't want to waste my tuners time or my money for a tune that is just temporary. I'd rather fix everything and get it running properly.
Old 06-18-2012   #2229
What a hassle
Old 06-18-2012   #2230
Murlo26
Murlo26's Avatar
What a hassle
Yes, true, but self induced...I didn't need to go this far with the car
I have learned that running this power on a 4 cylinder takes a lot of extra care/time to get right...so I am trying to take my time.
I still feel like progress is being made...I'll get it soon I think.
Old 06-18-2012   #2231
You going to slippery rock on a sport compact day?
I'm probably going to take my bike out to one before too long.
Good call on not beating on the car with no good tune on it!
Old 06-18-2012   #2232
Murlo26
Murlo26's Avatar
Either a sport compact day or test and tune day, whichever is first and works with the schedule. I'd prefer a test and tune day as from what I have heard you can get more runs in and also those have had better track prep's (maybe, lol).
But I am down for whichever.
Honestly my first few runs are going to be rolling the car off the line...for pure trap speeds. then I will take a shot at launching the car. I want to try and get a good trap speed before I break anything
Old 06-18-2012   #2233
Tachyon
Tachyon's Avatar
Drives: Icarus
So are you still coming to the PG regardless?
-Sebastian Vettel
Old 06-18-2012   #2234
Murlo26
Murlo26's Avatar
No sadly, I have like real work I need to knock out, which is why I can't take vacation too.
Any free time I have will be used to work on the car and/or relax.
I need to really catch up on some projects otherwise I won't be able to take the time off I wanted to around 4th of July either.
Old 06-18-2012   #2235
Tachyon
Tachyon's Avatar
Drives: Icarus
Shitty
-Sebastian Vettel
Old 06-18-2012   #2236
Murlo26
Murlo26's Avatar
Shitty
Indeed, no choice though really, work is really heating up.
A ton of our engineers are dedicated to a huge job we have for wood burning power plants and I am stuck being the catch all as I am still in the office.
I am hoping it gets better soon.
Old 06-18-2012   #2237
Don't worry man, plenty of time to hit the tracks this year. Plus racing an untuned car is retarded. Take your time and as long as you are making some progress its all good.
Although I was looking forward to seeing this in action, I can wait.
Old 06-18-2012   #2238
Murlo26
Murlo26's Avatar
^Got a GoPro Hero2HD now, so I will have plenty of film of when I finally go
Old 06-19-2012   #2239
Nice, I was looking up track days and 7/13 & 7/14 seems to be the next open days. Well that I can go I think the 7/1 weekend has some too.
Old 06-19-2012   #2240
Murlo26
Murlo26's Avatar
7/13 and 7/14 seem like a good weekend to shoot for, gives enough time to make sure its running tip top. And gives me time to get a helmet...I want to go try some on.
Tags
casual mention of an evo, cold little murlo, daves sexcapades, flip flop, flip flopppp, hotdog crank polishing, manifold butthurt?, sexy time.
