Old 05-08-2013   #1321
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: beaterX project thread
If I am not hanging with the woman that night I could swing by to help, just text if you need it.
Old 05-08-2013   #1322
Man, you need a lift!
I'd love one but I don't think I do actually! It sure would let me do this entire job by myself if I have to, but that sure is no fun!
Sounds good!
Old 05-10-2013   #1323
Stuff happened. Dropped motor out in about an hour of goofing around. Would recommend this method to any X owner, it was almost painless. Only snag is really being careful about seperating the steering column.
Once we used the hoist to get the engine on the ground we bolted up to the engine mount points and started lifting:
Didn't have to go nearly as high as you would expect, only about a foot:
Then roll it out the side:
Engine is very stable on two wheel dollies and some 2x12's, can move it around without fear of tipping or anything.
Clear the decks, then lower chassis back down nice and slow.
End result is a bunch of shit out of the car, super easy to disassemble...:
...an empty engine bay...:
...and a happy scheides
Thanks Rosey, Spaz, Shawn, Murlo, and Anna! Having extra hands is always a huge plus--safety first!
Once it was out I spent about an hour or so and popped off axels, all manifolds, accessories, turbo system (as a whole), etc then put her to bed for the night:
Final shoutout to Ron@RS for giving me this idea of going 'out the bottom' it was way easier than I thought it would be!
Old 05-10-2013   #1324
Nice
Old 05-10-2013   #1325
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
Went very smoothly. Glad to help, glad it went well!
Old 05-10-2013   #1326
That's cool that you took it out the bottom, my dad always says it'd be easier but I never believed him.
When you put it all back together will you have to get an alignment because you took so many things apart?
Old 05-10-2013   #1327
simulatedwood
Drives: 08 Evolution X
Aaaaannndddd We fixed Scheides air compressor too last night! Who knew you could blow a head gasket on an air compressor... must be a mitsu designed part.
Old 05-10-2013   #1328
I don't really think so, the strut bolts will all go back in the way they came out (arrows in on top bolts), the subframe bolts are immobile, the tie rods and everything else is untouched other than being lowered to the floor. Steering rack will need to be bled but as long as I get the steering wheel back in straight there should be no other problems.
Old 05-10-2013   #1329
rose0529
rose0529's Avatar
Drives: a red car
Oh nice!! What did you do to it after I left?
Old 05-10-2013   #1330
Ohhh thats nice then! When you think you'll have it back up and ripping around?
Old 05-10-2013   #1331
lmfao that was the most amazing thing I've seen in a while man! Frickin dude pulls the head off my air compressor and examines cyl walls, piston, and then yanks a make-a-gasket roll off the shelf of my garage, cuts out a new one, slaps it in and shit is golden. Unreal.
Old 05-10-2013   #1332
Unsure, life and work are my first priorities...lots going on so the car will get my attention when I have time. I'll get the block/trans apart and on the stand over the next few days or early next week, make sure the head still looks good, and go from there. Just hoping to have it back together and broken in by early June.
Old 05-10-2013   #1333
Tachyon
Tachyon's Avatar
Drives: Icarus
Nice! Who are you going to have tune your air compressor?
-Sebastian Vettel
Old 05-10-2013   #1334
I'm remote tuning it.
Old 05-10-2013   #1335
Yea it idles fantastic now! WOT only a few pulls but now that we have the motor back together I gotta hook up the wideband and see what it's doing. Planning on running ~100psi of boost on the first pull, let'r buck!
Old 05-10-2013   #1336
100psi first pull!!!
Boss move right there!
Old 05-10-2013   #1337
LOL, that's good shit
Old 05-11-2013   #1338
Spent a little time this afternoon and yanked xfer case, pulled out the transmission, and tore down to the shortblock.
Also took a pile of my spare valve tappets and sorted out valve clearances...we'll see how well my math works when I bolt the head to the new shortblock.
Old 05-11-2013   #1339
Nice! Just gotta put everything back together now or what?
I could never do an engine with buckets on my own. Seems way too complicated for this dumb ass prison guard.
Old 05-11-2013   #1340
Once you've done it a few times it's not so bad
Injectors are in the mail to FIC to get cleaned/tested and I think its time to buy some new flywheel bolts. I have to unmount the current shortblock and unpack/clean up the new one...I may assemble the longblock tomorrow but I need to decide about getting the flywheel turned and a few other things so I don't think I'll get too much further than that.
