Old 05-15-2013   #461
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: my new project
My current motor build I ran normal oil til 3k to be safe. My first motor build I switched at like 1000.
I would go longer but I have nothing to back that up. I think Gosh told Danny at DB to try using the regular stuff longer the second time around.
Old 05-15-2013   #462
4seasons69
4seasons69's Avatar
Re: my new project
Hmm yeah map recommends 1500 miles. Most say at least 1k. I'll probably just find a good heavy conventional and run that until 1500 or so
Old 05-15-2013   #463
blackawdtsi
Drives: 2G DSM
Re: my new project
paranoid that the will cause a problem. I just over think things. Bearings will be reused. And it will be using to a good heavy oil.
Anyone have any opinions on switching to synthetic before 1k miles? I'm thinking about switching to synthetic when I get it up and running. Is 625 miles too soon?
Valvoline VR1 non synthetic is probably your cheapest safe bet. Throw in a break in additive if you're keepin with the paranoid theme.
Old 05-15-2013   #464
4seasons69
4seasons69's Avatar
Re: my new project
Thanks! I'll check that out. I ran amsoil break in oil for the first 250 miles so right now I think I'll stick with a regular conventional.
Old 05-15-2013   #465
blackawdtsi
Drives: 2G DSM
Re: my new project
http://store.forcedperformance.net/m...otor%20Oil.pdf
Old 05-15-2013   #466
4seasons69
4seasons69's Avatar
Re: my new project
Originally Posted by blackawdtsi View Post
That's a good read! I think I've heard about that but never actually read it. I will definitely be using one of the oils off of that chart.
Old 05-15-2013   #467
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: my new project
Remember when I mentioned using 50 weight V-twin stopped my rod spinning issues?
-Sebastian Vettel
Old 05-15-2013   #468
4seasons69
4seasons69's Avatar
Re: my new project
I do! And that is exactly what I'm planning on using. :-)
Old 05-15-2013   #469
Re: my new project
VR1 racing 10-30 looks like a good buy.
Old 05-15-2013   #470
4seasons69
4seasons69's Avatar
Re: my new project
Indeed! I will worry more about oil when we are closer to starting this thing up again
Old 05-15-2013   #471
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
Re: my new project
I'm still running non-synthetic VR1 20w50 in my car. All I can say is it works fine in my motor. It's relatively cheap and you can buy it pretty much anywhere.
Old 05-16-2013   #472
4seasons69
4seasons69's Avatar
Re: my new project
Good to know. I will keep this in mind.
Old 05-16-2013   #473
Re: my new project
If you change oil enough I'd run non-synthetic.
Old 05-16-2013   #474
4seasons69
4seasons69's Avatar
Re: my new project
Well if this thing ever runs for more than 200 miles at a time I plan on changing the oil probably very 2 to 3k miles whether I stick with conventional or go synthetic.
Old 05-16-2013   #475
Re: my new project
I'd say find a good non-syn with good zinc and phos. then if you get to that point switch.
Old 05-20-2013   #476
dsmolition
chemist
dsmolition's Avatar
Drives: RR Evo 8
Re: my new project
I hope everything goes good for ya, its crazy how similar your car looks to mine in that video.
dsmolition is offline   Reply With Quote
Old 05-20-2013   #477
4seasons69
4seasons69's Avatar
Re: my new project
Thanks! That must be one nice looking car then!
Old 05-21-2013   #478
4seasons69
4seasons69's Avatar
Re: my new project
So here's a little update. Haven't done much with the car but I have an oil pump and timing belt on its way. Hopefully it will be here sometime this week. Then the plan is to put that stuff in and re-time the engine and do a compression test. The if the compression test is bad (I'm assuming it will be. I find it hard to believe there won't be bent valve) I'll do a leak down test to find out where we're losing compression. Then we'll go from there
Also once the car is ready to be fired up again before I do my going to tow it to my work and do an engine flush. My work has a machine that hooks up to the oil filter housing and where the drain plug goes and runs an oil based cleaning solution through the oiling system. Hopefully that will remove any metal left in any oil passages.
Now I just need some motivation to work on this thing lol
Old 05-21-2013   #479
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: my new project
Hang in there man, just think 700hp is just a few more tear downs away haha, just kidding!! Im very excited to see this beast put down, ive been following this thread for quite some time
2006 WW IX RS 396/404 - SOLD
Old 05-21-2013   #480
4seasons69
4seasons69's Avatar
Re: my new project
Haha with my luck it will be a few more tear downs before things go well for me lol. Well hopefully things go well after its back up and running! You and the people on this site have definitely helped keep motivated to keep working on this thing! Thanks!
