Old 05-28-2013   #781
simulatedwood
Drives: 08 Evolution X
Nice work Kracka, Loving the BBS wheels as they are very nice upgrade!
Old 05-28-2013   #782
The steering is definitely lighter. The car seems a little more responsive from a stop, but that could just be psychological.
Old 05-28-2013   #783
Wheels look nice.
Old 06-20-2013   #784
YAY! It's paid-off!
Old 06-20-2013   #785
Nice! No car payment ftw!
Old 07-05-2013   #786
Blah blah blah...more of the same. I finished up my 60k maintenance items on Wednesday by changing the coolant and replacing the factory serpentine belt and pullies with Gates brand parts. I'm pretty sure the OEM and Gates pullies are identical; the markings are all the same and they're both made in Canada. Us X guys replace these with the belt since they're made of plastic; after 58k miles my OEM ones still looked 99% fine, but I already had them sitting here and at only $9/each I figured better safe than sorry.
In a bit here I'll be taking my car in to the dealership for it's final warranty coverage inspection and an alignment. I've noticed some oil seepage on the underside of my engine and the front axle boots have been leaking grease (not cracked, but it appears the clamps aren't tight enough which is common).
All in all, not bad for a car with nearly 59k miles of daily-driven abuse!
Old 07-05-2013   #787
4seasons69
4seasons69's Avatar
Nice! I know gates makes a lot of oem parts for dealers. I've done timing belts on Hondas and we got the belts from the dealer and it said Honda by gates right on the belt lol
Old 07-08-2013   #788
Success! Axle covered under warranty and passed the state emissions test no problemo
Old 07-08-2013   #789
Tachyon
Tachyon's Avatar
Drives: Icarus
Factory clutch still going strong?
-Sebastian Vettel
Old 07-08-2013   #790
The factory clutch is still holding up just fine! [knock on wood]
Competition Clutch sent me a Stage 2 sprung HD kit earlier this spring but my stock clutch has still shown no signs of slipping or wearing out so I'm not going to bother with the install until it's needed. At which time I'll probably also do a front anti-sway bar and possibly a slightly lighter weight flywheel depending on the condition of my stock flywheel after all these miles.
Old 07-08-2013   #791
Tachyon
Tachyon's Avatar
Drives: Icarus
That's Nucking Futs
-Sebastian Vettel
Old 07-08-2013   #792
simulatedwood
Kracka,
I have 2 - used factory flywheels you can use when the time comes for clutch replacement. Not surprised your clutch has lasted, stock works very well if you don't have the massive torque spike in the tune to overwhelm it. Mine could have lasted another 30k, but knowing it would not last launching at the dragstrip, decided to upgrade for MAP PG TTS competition.
Old 07-08-2013   #793
Nice, that way I could get one resurfaced ahead of time so it's ready to go!
Still want to meet up when I'm up there in a few weeks to swap brake rotors, and now flywheel?
Old 07-08-2013   #794
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
You aren't driving the gheyrod here are you?
Old 07-08-2013   #795
simulatedwood
Yep sure, that works!
Old 07-08-2013   #796
Sure am, roadtrip adventure beast!!!
Old 07-08-2013   #797
Awesome! I will bring my stock front rotors as long as you still want them
Old 07-08-2013   #798
Murlo26
Murlo26's Avatar
nice! I want a ride if I am around (might be working in North Dakota). I want to see what the 2.5 feels like and roughly what to expect response wise. (as I know my car will only be better with the extra displacement).
If you have time for a fellow X'er of course
Old 07-08-2013   #799
Sure, buy me a beer and you can take it for a test-drive
Old 07-08-2013   #800
Murlo26
Murlo26's Avatar
Done
