Old 07-23-2014   #241
Re: Meet GheyRay: Lower, Wider, Lighter!
No lift to shift is awesome!
Starting with 2014, GM's 5.3 and 6.0 (or maybe its 6.2) require 0W20.
Oh wow, news to me, thanks. In other words, greasy water.
Old 07-23-2014   #242
I hate that word require. Is it really required? Or is it just for fuel economy reasons and youd actually be fine (and better protected) with a 30wt?
I'm with you there, especially in the heat down here I'd be much more comfortable with a 0W-30.
Old 07-23-2014   #243
Awhile back I did some reading, and it seems like the additive package provides more protection than the hot weight of the oil. At the high racing temps, say 270*, there isn't that much viscosity difference between a 30W and 40W oil. I guess a 20W oil is a bit thin though.
Anyway, sorry to hear about your oil overfill issues. Glad they are making it right.
Old 07-23-2014   #244
Good point! The additive packages these days are pretty incredible.
Old 07-23-2014   #245
polishmafia
Smells like cat poop
polishmafia's Avatar
Sorry to thread jack about oil, Kracka. What I want to know is... how was the no lift to shift!?
Old 07-23-2014   #246
I scared myself with it
Old 07-23-2014   #247
polishmafia
Awesome! Haha!
Old 07-23-2014   #248
NLTS is sweet. Since it's all computer controlled, what exactly does it change when you press the clutch but have the throttle down? Cut fuel and ignition? Does it actually leave the throttle body open?
Old 07-24-2014   #249
From what I can tell it operates similar to Tephra's NLTS on the Evo 8/9 by using a variable rev-limiter with a X RPM drop above Y% throttle and Z MPH. With my oil slightly over-filled I didn't want to mess around with it too much since I've been trying to baby it until the oil level is correct; hopefully I'll have more of a chance to mess around with it this weekend.
Speaking of throttle body though...
Weapon-X ported throttle body
The stock TB is 87mm but has a very large lip in it for some reason, this one reuses the stock blade but is fully ported and smoothed. For now it's getting added to the stack of boxes in my office, but it will be a good addition to the AFE intake I also have waiting to go on. I got a great deal from a local who decided the C7 isn't for him so I didn't want to pass it up. The hold-up to get these parts installed is two things:
1. Waiting to get my oil change debacle solved.
2. Waiting on Diablo to release their AFE intake OTS map, at which point I'll also order the Diablo InTune (think Cobb Accessport for domestics).
Old 07-24-2014   #250
Good shit. Would be cool to see a dyno graph of stock vs. these mods. Any plans to go get a baseline done?
Old 07-24-2014   #251
I've been thinking about it, I probably should!
Here is what Weapon-X claims for the throttle body. Stock vs. stock + ported TB (no tuning):
Old 07-24-2014   #252
Not bad at all. Im glad i did a baseline dyno on my car, kinda cool to be able to go back and see specifically your car and how it has changed.
Old 07-24-2014   #253
I'm going to talk to Cobb, they mentioned wanting to dyno my car vs. a 2014 Camaro SS at their next "First Thursday" event. That would be a great opportunity for a baseline.
Old 07-24-2014   #254
Dyno dyno dyno doooo it!
Old 07-24-2014   #255
Pretty healthy gains for just a TB and no tuning.
Old 08-07-2014   #256
The final piece needed for my nice basic little setup! They are supposed to be releasing a specific OTS map for the AFE intake sometime today or tomorrow in addition to the current 93, 91, and modified-stock maps already available.
Old 08-07-2014   #257
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
It'll be interesting to see what gains it will have with the intake.
Will they have anything in the future for the TB?
Old 08-07-2014   #258
Supposedly the stock ECU doesn't need recalibration for the ported TB. We shall see! This is a pretty common setup so luckily I'm not the first to try it out
Old 08-07-2014   #259
What kind of gains have people been seeing from it?
Old 08-07-2014   #260
For a stock car, about +20whp/+25wtq with just the 93-octane flash. With everything combined, we'll see once this AFE map is released
If I can dip out of work for a bit this afternoon I'm going in for a baseline dyno, and maybe do a pull with just the 93 map too if there's time.
