Old 08-22-2014   #1
dsmDolney
dsmDolney's Avatar
Drives: Racecars
NON Start issue
Okay so here is my problem. A couple weeks ago i came up to a stop sign and put inthe clutch and my car just died. And would not start back up would turn over and turn over but nothing. So i figured i ran out of gas. Went and got gas and still would not start. Figured i burnt my fuel pump up. So i put in a new fuel pump yesturday and still nothing. Then today i saw one of my spark plug wires were loose and put it back on nice and tight and it started right up then when i give it gas it would bog at first then would clear up later in the rpms. And now will not start it will just crank. I plugged in link on the laptop and it says my cps circut is bad so could that be why my car is not starting ?
Tyler
2011 Subaru Sti 11.0 @135mph
Old 08-23-2014   #2
Re: NON Start issue
CPS circuit?
Old 08-23-2014   #3
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Re: NON Start issue
This is what link says
Tyler
Old 08-23-2014   #4
Fran05
Drives: DSM
Re: NON Start issue
Crankwalk
Old 08-23-2014   #5
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Re: NON Start issue
I hope not could it be tho
Tyler
Old 08-23-2014   #6
mark4g63t
mark4g63t's Avatar
Drives: 95 Talon TSI
Re: NON Start issue
Have you checked fuses? Is yours still 7 bolt? Checked that all the sensors are plugged in/clean?
I believe I have some extra crank and cam sensors lying around, i'll try to dig them up.
BW8776, e-85
Old 08-23-2014   #7
jeremy1375
jeremy1375's Avatar
Re: NON Start issue
A bad coolant temp sensor will also cause a no start.
Old 08-23-2014   #8
Re: NON Start issue
Coolant temp shouldn't matter much, it would just run really rich on startup. Check your crankshaft end play, hopefully it's just the sensor.
Old 08-23-2014   #9
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Re: NON Start issue
Got a new sensor already does it need to be aligned with the cam sensor or anything or can i just swap the crank sensors
Tyler
Old 08-23-2014   #10
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: NON Start issue
I was thinking the same thing when I read it stalled when he pushed the clutch in. hopefully it hasn't gone walking and the sensor is just bad or the plug came loose. good luck.
11.35 @ 120mph
Old 08-23-2014   #11
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Re: NON Start issue
So im guessing it dont have to be aligned with the cam sensor correct
Tyler
Old 08-23-2014   #12
carltalon
carltalon's Avatar
Re: NON Start issue
The crank sensor just bolts in next to the crank under the timing cover there is no alighnment or adjustment,
11.35 @ 120mph
Old 08-23-2014   #13
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Re: NON Start issue
Okay thank you
Tyler
Old 08-23-2014   #14
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Re: NON Start issue
Well i think it walked it keeps poopin up that the cps is bad and i got the new sensor in. So i dont know what to do if someone maybe wants to come check it out before i tear it apart and give input thatll be cool but otherwise im done with it.
Tyler
Old 08-24-2014   #15
jeremy1375
jeremy1375's Avatar
Re: NON Start issue
Endplay check http://www.angelfire.com/pa4/awdcrankwalk/
Crankshaft endplay 0.0020 - 0.0071 per AllData for 96 AWD Turbo
Could be wiring issues also, so checking for crankwalk without tearing things apart might save you some time.
I should be available after Wednesday this week in the afternoons if you want help.
Old 08-24-2014   #16
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Re: NON Start issue
Yea dont really feel like rippin it apart unless i really have to so id like to make sure it walked before that or atleast figure out its not other things help would be nice for sure
Tyler
Old 08-24-2014   #17
jeremy1375
jeremy1375's Avatar
Re: NON Start issue
I'll know for sure on Wednesday when my freetime will be so I'll pm you then.
Old 08-24-2014   #18
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Re: NON Start issue
Sounds good thanks man
Tyler
Old 08-25-2014   #19
dsmDolney
dsmDolney's Avatar
Drives: Racecars
Re: NON Start issue
So im like 100% positive it walked so now to decide to part out and get an evo or just rebuild it
Tyler
Old 08-27-2014   #20
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: NON Start issue
Evos arent bad
Sorry to hear about the misfortune you're having
2006 WW IX RS 396/404 - SOLD
