Old 09-25-2014   #641
Re: Mark's 1G Winter Projects
:fap:
Old 09-25-2014   #642
Join the dark side with 2.0l of awsome.
Old 09-26-2014   #643
He is on that new hotness of 2.2L, that baller sauce!!!
Can't wait to results of this motor working!!!
In person!!!
Old 09-29-2014   #644
Capinoy123
Capinoy123's Avatar
Nice Work Mark! Great achievement to say the least.
Old 10-01-2014   #645
Mark Leasure
Mark Leasure's Avatar
Going 2.2l with a touch more comp ratio. 9.5 or 10.0:1. I need to reach out to chat about one of the items of the build with you.
In person!!!
Hotness
Thanks, it's been a fun process.
www.maperformance.com
Old 10-02-2014   #646
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Nice, join the goodness of 2.2L and 10 comp ratio I like where this is heading.
Old 10-25-2014   #647
Mark Leasure
I started the engine project. I'm using a evo ix piston to mock up the engine so I can clearance the block. So I removed it from the rod. I found it comical when I compare the oem evo rod to the billet one.
Old 10-25-2014   #648
Very nice.
Is that a pin I see for the bearing on the big end?
Excited to see some 2.2L goodness first hand
Old 10-25-2014   #649
Should be for oil, not a pin.
NSX - S480/Built motor
GSX - 571whp/490wtq
Sienna
Old 10-25-2014   #650
mondale
Drives: 1g dsm
The pin is to stop the bearing from spinning in an aluminum rod, which expands more than its steel counterpart. The bearing has a receiver hole that the pin fits in. They look nice!
8.59 @ 158
mondale is offline   Reply With Quote
Old 10-25-2014   #651
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Thus the reason for needing your rod bearings drilled when running aluminum rods.
Old 11-08-2014   #652
Mark Leasure
Super stoked! I clearanced my block today for the 94mm stroke 2.2 madness. With the huge r&r aluminum rods. No issues with the oil galley, that was the risk. Stay tuned for some boss shit on the way.
Old 11-08-2014   #653
Mark Leasure
Yep 100%. r&r drills your rod bearings for you for 40 bucks, worth it!
Old 11-08-2014   #654
b00sted_spyder
Damn, baller status!
Old 11-08-2014   #655
Damn, I'd love to see this in person
Old 11-08-2014   #656
X2, I need to see this build.
Old 11-09-2014   #657
IF you don't mind an audience, I'll bring the beer!
Old 11-09-2014   #658
Do you port the oil passages in the block?
Old 11-16-2014   #659
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Always a joy to read up what projects youre doing!
2006 WW IX RS 396/404 - SOLD
Old 11-16-2014   #660
Enes
Enes's Avatar
and i just caught up on this project.. read every post.
You man are a determined and skilled SOB.. mad props to you!
:bow:
