Old 04-24-2017   #61
Re: Back into the big leagues: Project FRC
Every time I click on this I'm hoping to see an On3 turbo kit was purchased lol
Old 04-24-2017   #62
Haha, I don't need any more power right now to go faster. If anything a wider tire setup may be helpful here soon or a dedicated set; but more power puts me in another class to where I won't be competitive for autocross.
Honestly not sure if I'll turbo this one. I may just build it up for 400+ NA and then spray it for drag racing when that time comes.
Old 04-24-2017   #63
https://jet.com/product/detail/6f3db...a:2&code=PLA15
Look, it even lets you order 2 of the big ones!
Old 04-24-2017   #64
Damn if they were on amazon prime I could get them by tonight and be ready for racewarz next weekend!
Old 04-24-2017   #65
You are in luck!
https://www.amazon.com/NOS-05029-Sne...rds=nos+system
Old 05-17-2017   #66
Got the brakes and new shocks installed the first weekend in May.
I really like the DRM (Doug Rippie Motorsports) valved Bilstein shocks compared to the C5 Z06 shocks (2003 stuff). I spent a good half an hour one night chatting with Randy about the settings/valving and was pleased with the responses.
I also forgot how good it feels to have stainless steel lines.
Parts installed in this go around:
Doug Rippie Motorsports custom valved Bilstein shocks
Doug Rippie Motorsports Stainless Steel front brake caliper piston upgrade
Russell Performance DOT Brake lines
Centric Brake rotors
Stoptech Street Performance Pads
Motul RBF 600 Brake fluid (did the clutch too)
Russell Performance Speed Bleeders
The theme of this car of "bang for the buck" continues with these parts selections. As this car is a street warrior with triple duty as autocross car and drag racing (which every event I try to go to get's rained out), I needed a compromise on the pad and rotor material. I feel these are the perfect solution to those 3 uses. I know they are not a track pad and rotor combo, but the lines + caliper pistons + brake fluid allows me to swap the rotors and pads for track duty when that time comes.
I was going to paint the calipers while I was there, but figured I'll have time to do that later when I am bored; time didn't permit for this install period.
So that's it. Until I start another round of upgrades I no longer have parts to install for this car. I am deciding what needs to be done next, but for now just more seat time in various styles of racing to flush out the bugs. So far the car is fairly stout in autocross and I think adjustable swaybar end links may be helpful if I need to start to dial in preload perhaps (or get to my other holes in the front swaybar I drilled). Another thought is pick up another pair of 18" wheels to go square setup for autocross use only.
Drag racing I am thinking a built rear end with possibly a shorter gear ratio would be helpful, but the gear swap and that puts me in another class. I think a chassis belly brace and a rear differential brace are allowed by rules, still trying to determine the spirit of the wording on that (Street Touring SCCA rulebook)
Of course I'd LOVE to do head/cam upgrade on it, but then I for sure have to go to CAM-T versus STU; and I am not done seeing how this thing does in Z class STU. The 5th (Ryan) and 8th place (Me) finishes so far (Mowog 2) are promising, I should have taken 7th in that event as I blew one corner. Next event is June 4th at what I consider my home base, DCTC; so I'll see if I can catch Ryan; but I have to really learn to read the course better. Once I catch Ryan I'll be comfortable adding more power.
In the end, I'll probably just start building a wicked oil cooler setup that'll hold up for track and street duty. I don't like the corvette tax associated with what is on the market, so DIY it is. If I can make a nice enough of a setup, maybe it'll become a Complete Tuning Solutions product offering.
Overall I am very happy with this purchase and how this car is setup right now. I set out a goal of building a 110% better C5 FRC and that is what I have. I truly think of it as a Z06 light. A bit short on power and the shorter 2nd gear ratio in the Z06 shines on the autocross, but handling/braking/weight/driver feel is much improved compared to the canvas I started with. But for a car that *should* go low 13's, high 12's in the 1/4 mile, is a blast to drive and competitive on an autocross course, and is averaging 22mpg city/highway (30+ on the highway is normal); I couldn't be happier.
Old 05-17-2017   #67
Good stuff man. Solid incremental mods!
Old 05-17-2017   #68
I dig it! I used those same rotors and pads on one of my Evos.
Old 05-18-2017   #69
Yeah, love the small incremental mods. And the best part, there's no mention of race gas like the old days of slapping on bigger and bigger turbos. I love the idea of a high 12-second car that you can run in many types of race events and still easily drive home without a thought. Maybe Curt Gendron was on to something all those years ago.
Old 05-18-2017   #70
Love this thread, i agree totally for a NA build then spray to take care of the straight line/power desires.
Old 05-25-2017   #71
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
How did the brake pads do? Or how are you liking them so far...just ordered me a set of stop tech front pads...finding rear pads for a 1G dsm is quite the pain so ill just go with some ceramic of the shelve pads and flush the system with motul 600 as well. Gonna have to brake boost quite a bit to get that new turbo to spool up lol
Old 05-26-2017   #72
My 1.5-cents: My biggest complaint with the Stoptech Street pads was the dust; performance-wise they were fine for the street and casual autocross. With that said, there have been a lot of pads I've liked better. If I'm going to put up with dust, it will be for the Girodisc S/S "orange" pads. For low-dust, RacingBrake ET500 or PowerStop Z26.
Old 05-26-2017   #73
They are "okay" pads. Stop well on the street but dusty. I'll use them and try a different street compound later.
Old 08-07-2017   #74
Finally got the car to the drag strip at the end of July.
XS Power longtubes - Catted
Corsa Catback
Air Bridge from Southern Car Parts
Blackwing Intake
MSD Wires
Tuned by me (Complete Tuning Solutions)
83,500 miles, untouched drivetrain and engine from throttle body to exhaust ports.
Bunch of autocross bits and other non go fast straight line mods: including alignment, DRM Shocks, DRM steering rack bushing, DRM caliper pistons, SS brake lines, C6 Z51 swaybars, six shooter shifter, etc.
Which category?
- External Engine Modifications (Bolt-Ons)
Example for 1/4 mile:
60'............. 2.012
330'........... 5.546
660'........... 8.405
660’ mph... 86.45
1000'.......... 10.832
1320'.......... 12.877
1320’ mph… 110.42
Comments:
OEM clutch wouldn't take more than a 2500 rpm slip without turning the car into a CVT with massive clutch slip. Best 60' was a 2.001 with a slightly more agressive slip, ran a 12.95 and a 12.96 to back it up. Rockfalls Raceway 7/31/17, 838 foot elevation.
Density Altitude: 2721 feet
Relative Density: 92.28 %
(per drag times calculator)
Next up is a clutch upgrade!
Old 08-07-2017   #75
93gtpeater
Drives: cbr 1000rr repsol
Very nice. I plan on going this weekend with my vette. I hope i can pull off a 12 sec pass. Might be hard as I don't have headers or much seat time launching the car. Congrats on the time slip. Think you could of gotten 12.5x with a better clutch?
Old 08-07-2017   #76
I hope they have some test and tunes in September as we are out of town every weekend this month. I might even run up for Wednesday night drags at Brainerd some night. I'm itching to see what this thing will do with just an intake.
Old 08-08-2017   #77
Yeah the car should have a 12.5x in it with cooler temps and a better clutch. I'll find out later this year hopefully.
Old 08-08-2017   #78
Good job.
And hey I like that term "Engine untouched from TB to exhaust ports". I'm gunna start using that on the supra boards! Huge turbo sure, but its stock from TB to exhaust ports!
Old 08-08-2017   #79
I always list my oil type as a mod, so mine's not stock.
Old 08-08-2017   #80
Good job.
Haha the vet guys are particular. The post was written keeping them in mind. Essentially I can upgrade throttle body, intake, maf and pick up more power and still be "bolt on" category.
When I put a cam in it, opens up to another group.
Essentially the car has most of the easy bolt ons.
New clutch ordered. Hope to install weekend of 19th and back to track the 27th. I'd like to see a 12.5x and 111+ mph next time out.
