Old 12-22-2007   #1
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Exclamation 95 talon probley
My gf has a 95 tsi awd auto it has 14b, knock off bov otherwise stock.It was running fine, but the other day she came home and heard a bang. The car wouldnt go over 15 mph. I went out to start it but wouldnt idle.. Heard exhaust leak coming from the front of engine. I then pulled off piping and checked the turbo but no play. The exhaust bolts off the o2 housing were lose so i checked the gasket and it was good so i tightend them back up. Started the car it ran for 2 sec then it died, started again and reved up but it started to miss but then it would idle... Revved up to 3500 held for a sec and it missed bad. Any help would surely be appreciated!!!!!
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 12-22-2007   #2
Re: 95 talon probley
Did the timing belt skip? Check the timing. There are a ton of other possibilities. I would do a compression check also. Those 2 things would eliminate quite a bit.
Old 12-22-2007   #3
GsXtUrBo98
GsXtUrBo98's Avatar
Ok that sounds like a start... Ill try that and post again in a bit. If there are anymore things just let me know.. I appreciate it
98 GSX (built)
03 BBY EVO dd
Old 12-22-2007   #4
Yup, do what JET said, then check the spark plugs and plugwires and make sure all is well there. Try resetting the ECU while you're at it.
Old 12-22-2007   #5
GsXtUrBo98
GsXtUrBo98's Avatar
How do you reset the ecu??
98 GSX (built)
03 BBY EVO dd
Old 12-22-2007   #6
gstjoker
gstjoker's Avatar
Unplug the negative wire on the battery for about 2 minutes or so and reconnect it back.
Old 12-23-2007   #7
GsXtUrBo98
GsXtUrBo98's Avatar
Ok thanks thats what i thought but i wanted to be sure.
98 GSX (built)
03 BBY EVO dd
Old 12-23-2007   #8
mdost03
Sonic Champion!
Drives: VA STI
I would say intercooler piping blew off somewhere. Do a boost-leak test.
Old 12-23-2007   #9
GsXtUrBo98
GsXtUrBo98's Avatar
Ya i kinda figured it might be a boost leak aslo...
98 GSX (built)
03 BBY EVO dd
Old 01-09-2008   #10
GsXtUrBo98
GsXtUrBo98's Avatar
Ran a compression test and it ran 165 across the board, and did a vacum test and the egr had a slight vacum leak... still having problems and any help would be great..
I want to do a fuel pressure check but not sure how too... I dont have the tools to do so so if anyone would be willing to help me out on it that would be greatly apperciated!!!! I dont wanna buy the pressure tester so please lend me a hand
98 GSX (built)
03 BBY EVO dd
Old 01-09-2008   #11
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Check to make sure all the injector clips are on nice and tight.
Old 01-09-2008   #12
GsXtUrBo98
GsXtUrBo98's Avatar
Ok ill check that out and update but still if anyone would lend a tool to do the fuel pressure check that would be cool too
98 GSX (built)
03 BBY EVO dd
Old 01-10-2008   #13
GsXtUrBo98
GsXtUrBo98's Avatar
Poblem fixed today so im good now
98 GSX (built)
03 BBY EVO dd
Old 01-10-2008   #14
GsXtUrBo98
GsXtUrBo98's Avatar
It was a bad boost leak and I fixed it just incase anyone wanted to know
98 GSX (built)
03 BBY EVO dd
