Old 11-14-2004   #1
john
Business as usual
john's Avatar
No spark, No fuel, ...
Car has no spark, no fuel, stock boost gauge does not go to 0 when cranking or in the acc position. Has to be something with the ecu??? I was messing with the plugs a while ago. It is not even bolted in place.
97 Viper GTS
Old 11-14-2004   #2
john
Business as usual
john's Avatar
BTW, MPI fuse along with the others appear to be fine. I checked the plugs for fuel and I also pulled the return line.
97 Viper GTS
Old 11-14-2004   #3
john
Business as usual
john's Avatar
problem fixed
97 Viper GTS
Old 11-14-2004   #4
LightningGSX
Hellbound
What was it?
-Nulli Secundus-
Old 11-15-2004   #5
john
Business as usual
john's Avatar
My ecu was shot and there is a metal resistor box or something that is located under the center console that was not plugged in or bolted down. It appears to connect into part of the wiring coming off the ecu. I tried QPR's ecu and it acted the same as mine did until I plugged in the box. I tried swapping my ecu back in but it did not work.
Can you look at my ecu to see if it is fixable? I have an extra EPROM but the winter beater does not need it as it will remain mostly stock. I also have a couple CAS' that I would like you to check.
97 Viper GTS
