Old 12-11-2012   #741
Some day I will do that for you. Maybe once the stock clutch goes and it's replaced with something a bit beefier.
Old 12-11-2012   #742
Yea I agree, for the "ultimate street turbo" you are after Kracka I don't see the advantage with the 2.5. Hell, my EF4 is only about 200rpms behind your turbo up to 27psi and I am not even on full mivec (obviously totally different setups, but still).
EF2 ftw on your car. /pray new cover helps.
I agree fully. My previous EF2 is the better "ultimate street turbo" all things considered, but we'll see how the standard cover performs. If I can gain back half the spool lost then I think we'll have a viable contender. MAP has asked me to get it done so I'll be calling Cobb to get something on the calendar.
Old 12-11-2012   #743
Cobb's power board, before & after:
15th ---> 13th
Old 12-11-2012   #744
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Those cars area all really close. I guess for good reason, stock block cars I am guessing.
Old 12-11-2012   #745
You can scan the QR codes, or just go to their online dyno database for all the info/details on each setup (since you probably can't scan the tiny on-screen codes).
Old 12-11-2012   #746
What kind of gains do you think some cams would net you?
Old 12-11-2012   #747
A lot Cobb keeps pushing me towards Kelford-B cams, but I keep pushing back fighting to keep my stock-like smoothness and drivability.
I'll have standard 3" compressor cover results on Saturday, December 22nd.
Old 12-18-2012   #748
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
are they planning to try this ef2.5 on the evo 8/9s?
2006 WW IX RS 396/404 - SOLD
Old 12-19-2012   #749
Depends on the results on the X, but if it's a solid performer and sells well, then yes.
Old 12-20-2012   #750
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
yeah i was at map yesterday doesnt sound like its in the plans but like you say if it performs why not
Old 12-21-2012   #751
Standard cover testing begins today. GheyrodX had a sleepover last night with some foxy Subaru bitches
Old 12-21-2012   #752
Murlo26
Murlo26's Avatar
I approve of your description of Subaru's as bitches
Good luck.
Old 12-21-2012   #753
Tachyon
Tachyon's Avatar
Drives: Icarus
Nice! Looking forward to seeing this next week.
-Sebastian Vettel
Old 12-22-2012   #754
Here are my latest results, these are with the standard 3" compressor cover rather than the 3" anti-surge cover. This seems to be the winning setup if you ask me; 200 RPM quicker spool, better response, more torque, nearly identical horsepower, and of course one less option to pay for
Driving impressions are great! No surge issues could be felt and it drove very nicely. Initial impressions are it drives just as smooth as the anti-surge version, but give me another few days to truly experience the turbo in more scenarios. Oddly enough, turbo intake noise is slightly more with the standard cover than with the anti-surge version.
My final verdict: Standard cover is the way to order this turbo. Save yourself a few bucks and enjoy the quicker spool/response times!
Old 12-22-2012   #755
Badass! I was second-guessing this wheel combo but it looks pretty pimp now!
Old 12-22-2012   #756
Mark Leasure
Mark Leasure's Avatar
Looks like good results with the std cover. Nice power on 93 too.
www.maperformance.com
Old 12-23-2012   #757
More power under almost the entire curve too! Nice!
It would be nice to see an over lay of the standard cover EF2.5 vs the EF2 once they get the database updated.
Old 12-23-2012   #758
Should be available next week.
Old 12-29-2012   #759
EF2 vs EF 2.5 standard cover:
Not sure which I like better, the extra low end grunt of the EF2 or the higher peak and top end of the EF2.5.
Old 12-29-2012   #760
Murlo26
Murlo26's Avatar
I'd still take the 2. On a more basic setup, aka no porting, I might go for the 2.5 but his setup is efficient so 2 all the way
