Old 12-22-2012   #11
Re: Project Lex
I forgot, which rear diff are you using now? What will your speeds at redline look like for each gear?
My stock SC300 manual rear diff is 4.08, which 1st gear is basically worthless once you're making power on my 5spd. So once switching to a 6spd, it'd make it even that much more worthless. The stock 98+ SC400/SC430 is 3.26, and is what I'm now running. That is the same ratio as the JDM TT 6spd Supra's. USDM have a 3.13.
Speeds I don't know, but it should end up being very similar to a stock TT 6spd Supra. The rear diff is close, the 350z trans gearing is close.
