Old 07-09-2014   #11
7/8/14:
Got my axle warrantied and woot! no more leaks!! I checked the car last night and for the first time ever there is zero puddles under the car!! I'm amazed.
I do need to recheck the T-case and transmission to make sure they are topped off.
I was flushing coolant to put straight water/water wetter in and discovered that my Ebay made coolant overflow tank was leaking through the sight glass. wah wuh
So I picked up this for $7.70, being over 1 quart it is NHRA legal.
Finished install for now (need to redo my UICP):
Swapped out the unused 2G MDP sensor for this beautiful adapter made by ECMLink:
90% finished install, need to get rid of that blue hose and block that line off, then the wiring will be done better once I redo the UICP.
Going to try and hookup a cooling fan switch, shift box, and vacuum pump, check T-case, and maybe tune a bit today before work. (7/9/14)
