Old 06-03-2015   #35
Re: Project Black ValentNine AKA DSM9.0
Gl on the rebuild. Ensure you check the rod on cylinder #3 as well to make sure length is correct and the bearing isn't damaged. I would probably just replace bearings in the lower end at a minimum but I can't bring myself to do anything but a full rebuild on anything.
Oh and straight definitions are the same. I forget they put a slalom in the rear one.
