Old 12-06-2010   #701
Re: beaterX project thread
Shitty. Does it sound like it's starving for fuel or what?
Old 12-06-2010   #702
No, like a hard shutoff from the ecu. It runs perfectly for 3 secs, then dies. Checked a ton of the sensors, everything seems to be plugged in. I found a loose bolt for the positive alternator lead but that didn't change anything. Battery is strong too.
Old 12-06-2010   #703
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
MAF issue possibly? I am trying to think what could be wrong, that is strange.
Old 12-06-2010   #704
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
Hey which plugs did danny have mixed around on your car that night i was up there with jake getting his car tuned.
341hp/344tq E-85 FTW
Shane Tune@ DB
Old 12-06-2010   #705
Murlo26
Murlo26's Avatar
AC and starter...but my car didn't start at all. They are the same damn plug and very close to each other. But like I said, my car wouldn't start at all.
Old 12-06-2010   #706
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Almost sounds like a relay. Are those a returnless fuel system? I guess I have no clue on the X setups. I read online that some people were having issues with the key fob and the ecu not recognizing each other but Im not sure what factory option you have on your car.
Amsoil Dealer
Old 12-07-2010   #707
Not a fob issue and it looks like the plugs Murlo mentioned are correct--they only fit one way on my car. If I feather the throttle and keep it up around 3000rpm, it will sometimes stay running for a bit longer, maybe 8 seconds. I did find the iat sensor in the bumper wasn't plugged in, but the problem persists.
Old 12-07-2010   #708
Murlo26
Murlo26's Avatar
I forget about that sensor every time I take my bumper off, lol. Sometimes I have to take the bumper back off because it gets stuck between shit, stupid sensor.
Strange though about it not staying running, something is amiss for sure.
Old 12-07-2010   #709
Sounds exactly like what happens if you try to start an 8 with the wrong key.
Old 12-07-2010   #710
Nope.
Old 12-07-2010   #711
simulatedwood
Drives: 08 Evolution X
Did the flamadation valve go bad already?
Ahh hopefully you can this sorted out, sounds like the ecu is going into limp mode. My car will not run either when in limp mode, ironic I know.
Old 12-07-2010   #712
Stupid flamadation valve!
Things to check tonight:
-check CELs
-reflash latest known working rom onto ecu
-fuel pump relay?
-rag in an IC pipe
-pull valvecover,
--double check timing (maybe I did part of it wrong?)
--check chain stretch indicators
-figure out how to check/reset timing chain stretch setting in the ecu (need oem tool for this I think)
On the upside, the coolant leak appears to be fixed!
Old 12-07-2010   #713
Jim is puking his guts out from teh flu or something so I'm not going near him to get my cable. On top of that, I have an interview tomorrow and had work to do tonight, so when I got home I walked past the evo, gave it the finger, and came inside for a night away from it. It kinda kills me, but I don't want this stupid car to own me. I worked on it saturday 9:30am-1am and sunday 10:30am-9:45pm, and monday 7-10pm (after working 8-5/10-12).
I have to work tomorrow night too (I say this regularly....but just FYI I always work 8-5 in the office, and the nighttime stuff is usually after-hours deploys/upgrades/fixes for the same '40-hour' salary....just wanted to clarify that this is not like 'i have to work tonight but did nothing all day' kinda shit), but if I'm lucky I might get a few minutes to look at the car after I get home.
Old 12-07-2010   #714
DoughtCom
It's deluxe son... deluxe
DoughtCom's Avatar
Drives: Your mom
That sucks man I hope you get it figured out soon. Jim probably has the shit that's been going around, hope he's feeling better. Good luck on the job interview tomorrow too!
2010 Evo X GSR
1997 Subaru GC8 STi
Old 12-07-2010   #715
Sounds like that same shit I had a few weeks ago Lasted 3 days for me, sucked arse.
Old 12-07-2010   #716
cmspaz
Walls need hugs too
cmspaz's Avatar
Would my cable work or is it too old? I could drop it off in your garage tomorrow after work if it would be of assistance.
Originally Posted by Trogdor
Old 12-08-2010   #717
X requires a Tactrix 2.0 cable.
Old 12-09-2010   #718
From the garage (finally):
Pulled apart most ic piping, no rags stuffed anywhere. Also tried hooking up intake right to TB, no does exact same thing.
No CELs, only one was from when I started it with the sensor unplugged.
Reflashed ecu with stock rom, same thing.
Popped off valvecover, liquid gold (oil) everywhere, yay!
Gonna check timing and swap fuel pump relays.
Lomker, remember when your car wouldn't't start on that angle/grade? How low were you on gas? I have a solid 1/3 tank. Maybe I'll get a few gallons of gas to pour in?
Old 12-09-2010   #719
Murlo26
Murlo26's Avatar
I got stranded on a 1/4 tank once as well. Same thing as you were describing. Car would start and die after maybe 4-5 seconds. I could rev it to keep it going for maybe 10 seconds but it didn't want to stay running.
I filled up with a few gallons more and viola, it was fine again. Good thing to check, but seems unlikely at 1/3 of a tank.
Text me if you need me to check my car for anything for reference...hopefully you figure it out...i remember I looked at my cars wiring diagram and engine bay at DB with Danny and Brad? for like 2-3 hours and still nothing. Finally Danny swapped the two plugs and bam!
Its probably something simple.
I have extra relays too if you need some...somewhere around here.
Old 12-09-2010   #720
Timing is perfect, chain stretch marks are well within spec.
Swapped relays, no luck.
I'm going to go get some gas.
