Old 05-21-2010   #721
311evo
311evo's Avatar
Re: Evo X upgrades
Lol, no shots in the face for me. :P I'll leave that to the wemans.
Old 05-21-2010   #722
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Originally Posted by 311evo View Post
just to have the piece of mind that you knew what came out, and what went in.
During break-in it was being changed every 4-5 days. Going forward it'll only need to be changed monthly, at most. That'll be worth the trip to Dad's house. If I had a driveway then I'd do it but I live downtown and the meter reader would have fun with that one.
Old 05-21-2010   #723
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: Evo X upgrades
Any word on if it will be ready for you on Monday?
7/25/09
Old 05-21-2010   #724
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I should send Shane a masseuse. Nothing but crap and too much work.
Old 05-21-2010   #725
Re: Evo X upgrades
Dude, we've told you countless times now that if you need to change your oil, JUST ASK! Plenty of us have driveways and garages with all the tools you'd need.
Old 05-21-2010   #726
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I will, just wanted to get to know some of you better before I did. In this case it isn't relevant because if I'd known I could have had Valvoline fix it on the spot.
Old 05-21-2010   #727
Re: Evo X upgrades
Will it be back on the dyno for more tuning today?
Old 05-21-2010   #728
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Shane said he'd try to give me a mild tune that'd be safe for Monday. He is heading up to BIR for NASA so he has a hard time constraint. That's a long-winded way of saying: dunno.
The worst that could happen is I drink a lot more beer on Sunday night (if I'm not driving on Monday). I have a room in Baxter and I'm going to use it.
Old 05-21-2010   #729
Re: Evo X upgrades
When is the event you're attending? Gotta get those brake lines on...monday? Tuesday?
Old 05-21-2010   #730
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I wasn't expecting to get it done before BIR. Car is still at DB, working an all-nighter on Sat/Sun, then heading up to BIR Sunday evening. Track day is Monday. It's crazy season.
Old 05-21-2010   #731
Re: Evo X upgrades
OIC! Ok, then LMK when you wanna do it, I'm game for whenever. I owe you.
Old 05-21-2010   #732
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I picked up the car tonight. Shane put a tame tune on it...26psi and I think he said 15 degrees of timing? It makes decent power but it will need some polishing next week.
These ID2000 injectors start like a motherfucker when cold and the car barely runs for the first few minutes. On paper the spool is terrible, up around 4300. It doesn't feel bad driving it, though. Maybe the whole spool thing is over-rated.
The ECU is also acting a little weird. The driver's power window is no longer one-touch and the alarm system won't arm. I'm not sure if a fob is lost in the passenger compartment or if the computer just thinks one is there. We practically disassembled the interior looking for it, without luck. I'll be dropping the car back off at DB on Tuesday and we'll see what we can figure on that and polishing the tune.
Shane said the turbo is blowing some smoke on WOT pulls so there's definitely a chance that it'll have to come back out to be repaired. Who said ignorance was inexpensive? Considering what I've been through so far, that seems like a minor issue.
Old 05-21-2010   #733
GG_9_SE
E85=Win
GG_9_SE's Avatar
Drives: Evo 9 SE
Re: Evo X upgrades
those are still some pretty nice numbers for low boost, low timing, and possibly blown turbo!
341hp/344tq E-85 FTW
Shane Tune@ DB
Old 05-21-2010   #734
Re: Evo X upgrades
Yeah man! Problems suck, but once it's worked out and it makes good power, you forget about all that money spent. I did. Anyway, could the late spool be caused by a maladjusted boost controller? I know mine had the gain turned all the way up and was causing a crazy hysterisis where the waste gate would open a couple times at spool up, then close, make boost and work normally. Check that maybe?
Old 05-22-2010   #735
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
Re: Evo X upgrades
For the window it happens a lot on cars usually if you hold the switch going down all the way and hold it once it bottoms out then bring it all the way back up and hold it, it will reset the auto function and work again.
Old 05-22-2010   #736
311evo
311evo's Avatar
Re: Evo X upgrades
What turbo do you have again? the red?
Nice numbers so far, Craig is right on the windows.
As far as the security system check fuses, or somehow reactivate it.
You might be able to get these both warranted from Brookdale too, just sayin.
Old 05-22-2010   #737
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
It's weird because it goes down a couple inches every time that I press the switch. It goes up the whole way, like normal. I'll fiddle with it a bit.
This is the BBK Full for the X. They call it the BBX.
It's not a power issue...it just thinks a key fob is inside the car. DB couldn't find the key that I'd left them so at this point we don't know if that's true or not. We looked for it pretty thoroughly. The X's with SSS don't use an ignition key--it just detects a fob inside the car.
These injectors are really rough and I threw a CEL this morning. The car is making me nervous right now.
Old 05-22-2010   #738
Re: Evo X upgrades
Awesome power man, enjoy it.
Old 05-22-2010   #739
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Ended up being the random misfire code. The local dealers don't have new plugs in stock so I'm going to reinstall a set of HKS M40XL's that I already have. I had pulled those out quite a while ago since Shane didn't recommend one-step colder plugs with E85.
Old 05-22-2010   #740
Re: Evo X upgrades
Didn't get a VMail, but I assume that's you that called...I'll have your cable back in the cities tomorrow evening, I can bring it over to ya if you like!
410whp at only 26psi and 15 degrees of timing? That is a damn conservative tune for your setup, but it should get you used to the power before the big numbers. 400whp is plenty of fun for the street, enjoy it!
