Old 09-04-2013   #901
Re: Project Lex
Yay! You can have an air filter now!
Old 09-06-2013   #902
Re: Project Lex
That cleaned things up a lot, looks nice!
Old 09-10-2013   #903
Re: Project Lex
How I wired the new ignition, if anyone on here even cares lol.
Tried starting the car but it didn't start. My 12V appears to be missing for some reason so will have to troubleshoot that.
Name:	ignition - Copy.jpg
Old 09-12-2013   #904
Re: Project Lex
She's alive! Only had to change 1 setting in Megasquirt and she started right up. Need to solder in a jumper do the tach works. Also appears my noise issue at 3k rpm may be gone
http://www.youtube.com/watch?v=9KI2f9s9BOA&hd=1
Old 09-13-2013   #905
Re: Project Lex
Nice!
Old 09-13-2013   #906
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
Re: Project Lex
sounds so good.
Originally Posted by 311evo
Old 09-13-2013   #907
Re: Project Lex
Always nice when things work out! Good job y0
Old 09-13-2013   #908
Re: Project Lex
Soldered in a jumper across R109 on the gauge cluster, tach is operational again
Old 09-13-2013   #909
Re: Project Lex
Eff yeah time to make 600whp
Old 10-15-2013   #910
Re: Project Lex
Couple updates.
LSD installed (Thanks MAP) and diff filled with Amsoil. Bought new rear axles since one is flinging grease all over, need to install them.
Also scored a deal on a 3" exhaust for like $300. I was getting sick of my homemade exhaust, wobbled and banged around too much. This one is much more solid. I installed it but it needs a little tweaking to get around the 350z trans mount. I'm also considering throwing some huge oval straight thru Magnaflow inline under the driveshaft to quiet it down more.
Also picked up a set of black powder coated GE Valve Covers for dirt cheap. Threw them on, pretty nice considering what I paid for them.
Also I was going to build a front facing intake manifold. However I found this for dirt cheap so just bought it.
It came with this TB, however it's the same flange as a Q45 which I already have. So I'll chose one of them to run, and sell the other.
Had to take the old intake manifold off. Had to remove a bit of wiring while doing that, so I decided f-it and unhooked the entire harness. I'm going to clean up the wiring while I have this all apart, and try to do a mini-tuck. Goal is to just make the wiring look clean. Bought a shit ton of regular nylon loom online for this. I also never rewired my fuel pumps so I bought two relays (keep one as a spare in case the other one ever dies). I'm also going to rerun the wires going to my amp for my sub. At the risk of inviting the peanut gallery to tell me how they would do it different/better, I'll share anyway. To keep wiring clean, I only want to run 1 wire from the battery to the trunk (even though the pumps and the amp/sub both need power). So I'm going to run a single fused (80A) 4awg wire from the battery to the trunk. In the trunk I have a distribution block that will have two fused (40A) 8awg wires coming out of it. One will go to the fuel pumps, the other will go to my amp. Considering the twin pumps should never really be pulling more than 25A (estimate @ ~40psi boost), and my amp/sub setup is just a small basic little 200W amp powering a single 10" sub, I think the 4awg feed will be plenty to power both of these with no real voltage fluctuation.
Anyhow, pics of that progress:
So as you can see, I started on the passenger side. All those wires used to be ran in the engine bay along the edge of the bay. Now they will be ran through the wheel well to clean up the appearance. Also on the driver side, I got rid of the old ABS fuse box and wires. All that's left on that side is the main fuse box, and one wire connector that goes to the brake reservoir. I'm leaving the fuse box as is, but have extended the wires for the brake reservoir and ran it in the wheel well, so that side cleaned up a little bit too. Little by little I chip away at it every day. It's done for the year so I have all winter to get it done.
Old 10-15-2013   #911
Re: Project Lex
Nice work!
Looks like there is a ton of room in there.
Old 10-15-2013   #912
Re: Project Lex
Wire tuck and the new IM are gonna look *sick* dude! I'm excited to see once its done!!!
The only time you'll care about voltage drop on your fuel pumps is when you're WOT at high rpm and *cranking* the music. If you really want to test it, put on some earplugs, rev the car to like 3000-4000rpm, and crank the volume all the way up while you put a volt meter on your distro block (or even at the fuel pumps). If for some reason you get some voltage variation, get a phat capacitor and put it inline before the amp but after the distro block. Easy peasy.
No comment on noise or emf leaks, I don't have much experience with that.
[/peanuts]
Old 10-15-2013   #913
19TsiAwd90
19TsiAwd90's Avatar
Re: Project Lex
valve covers look good! so does that intake manifold. good call on doing the wire tuck now while its apart anyways.
Old 10-15-2013   #914
Re: Project Lex
Looking good!
Old 10-16-2013   #915
Re: Project Lex
Lookin good! Might as well take care of the AFM while you're at it too huh?
Old 10-16-2013   #916
Re: Project Lex
[/peanuts]
This is why I love having a gauge that shows voltage at the fuel pumps.
Old 10-16-2013   #917
Re: Project Lex
I'm not sure what that is?
Old 10-16-2013   #918
Re: Project Lex
The sweet MAF/MAS thing you have just chillin in the engine bay.
Old 10-16-2013   #919
Re: Project Lex
Yes I plan to remove that.
Old 10-16-2013   #920
Re: Project Lex
Thing is going to look even better when you're done with it than it already did.
Keep up the great work!
