Old 03-22-2011   #1
311evo
311evo's Avatar
Re: Evo X upgrades
^ word, I've read the same thing. Sometimes it seats properly and everything goes well, and sometimes they're bitches. I guess that's part of the risk with saving a shit ton of money.
Old 03-22-2011   #2
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I appreciate you being kind. Fact is that I was an even worse n00b at the time of the motor build and didn't completely understand the risk that I was taking.
I'll just keep adding oil and if I'm employed come Winter then I'll try to have it pulled and fixed. It's making good power, etc.
Old 03-22-2011   #3
311evo
311evo's Avatar
Re: Evo X upgrades
Not sure if serious, but if I came off as being a douche I wasn't trying.
Old 03-22-2011   #4
Re: Evo X upgrades
Wow that sucks.
Old 03-22-2011   #5
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Evo X upgrades
Compression is even at least like Kracka said
But I am curious what should these numbers be? I know Scheides numbers were like 150's...but is that where yours should be?
Old 03-22-2011   #6
Re: Evo X upgrades
Just turn the boost up!
Old 03-22-2011   #7
simulatedwood
Drives: 08 Evolution X
Re: Evo X upgrades
Sounds like a fat tire beer hone and a set of rings and she will be making good power again!
Old 03-22-2011   #8
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Ron said 135-145 is typical for an Evo. Some pistons are naturally tighter/looser than others. JE are known to be loose anyway.
FTMFW! It broke 450 as she sits, so who knows what it'd do with better compression.
Old 03-22-2011   #9
Re: Evo X upgrades
At least the hood looks nice!
Old 03-22-2011   #10
Murlo26
Murlo26's Avatar
Re: Evo X upgrades
Well like you said your car still makes very solid power...that just means you could've made even more I guess (insert bench racing blah blah blah here).
As long as it works this summer who cares...no downtime > good compression.
Old 03-22-2011   #11
Re: Evo X upgrades
Those compression numbers are definitely discouraging. Have you done a leakdown test?
Old 03-22-2011   #12
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Not at all. I made a bad decision but I didn't have enough information at the time.
No, partly due to the symptoms and partly because it was a brand-new head. MAP built it up from a new Mitsu core. The car has been blowing dipsticks, fouling front O2s and filling catch cans with blow-by since a few weeks after the build. I know that head issues can lower compression but could it be the cause of all the oil burning and other symptoms?
Old 03-22-2011   #13
Re: Evo X upgrades
That sucks. I messed up about three or four engines learning how to do it right. It's been in and out of the car at least six times, maybe seven, but that's moddin' cars for ya. You'll be really good at pulling the motor after the 3rd time. I can have mine out in an hour if I bust my ass.
I like the idea of pulling it apart, honing and new rings, then steady state WOT on the dyno for the first 10 minutes, and engine braking from 150mph to 10mph for the next 10 minutes.
Old 04-09-2011   #14
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
I had another great car day! Spent it with simulatedwood in Hastings
I started by changing all the fluids: motor oil, tranny, tcase, and rear diff. I went with the Redline cocktail for the tranny.
We then did the rear brakes. Girodisc one piece rotors, Carbotech XP8 pads, and Technafit stainless lines.
A little Motiv bleeding action, with ATE Super Blue.
Up front are Girodisc two-piece rotors, Carbotech XP10 pads, but the Technafit lines for the front didn't fit right in the brackets.
Rather than dick around, I threw `em out. I'll order up a set of Stoptech front lines since they replace the lines all the way to the caliper.
Old 04-09-2011   #15
Re: Evo X upgrades
Nice, i was right down there today as well.
Old 04-09-2011   #16
PlanoEvo
DL OG
PlanoEvo's Avatar
Drives: Evo IX SE
Re: Evo X upgrades
looking good!
Actually, i lied, hang around the drinking league if you want to party hard.
PlanoEvo is offline   Reply With Quote
Old 04-10-2011   #17
Re: Evo X upgrades
Very nice! Technafit's customer service is great, you should at least send them back for a refund...or replaced with the correctly made lines.
Old 04-10-2011   #18
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
The Technafit kit is a poor design. It comes with front & rear lines for cheap ($80 or so) but the front lines only go from car to bracket and use stock lines from bracket to caliper. Once they didn't fit...I threw them away. I wasn't going to remove the rear lines since they were already installed and Shawn's time was limited.
I bought the lines like a year ago based on recommendations...I didn't realize the limitation when I bought them. I ordered a set of the Stoptech front lines this morning ($90).
Old 04-10-2011   #19
Re: Evo X upgrades
Gotcha.
Be sure to periodically check for fitment/rubbing issues no matter what brand of SS brake lines you have; mine moved slowly over time and ended up rubbing and eventually blew out on the highway during a hard stop coming down from 80.
Old 04-10-2011   #20
mlomker
*Resting In Peace*
mlomker's Avatar
Re: Evo X upgrades
Will do. Was planning on total fluid changes every 15k miles (once per year for me) since the car is more of a toy than a driver.
