Old 10-16-2005   #11
Re: Wheel spin developed recently in all gears except 5th
Originally Posted by JET
That was the 90's, the later ones you just take the rubber cap off, push in the retaining pin and use a 2.5mm allen wrench to unscrew the valve. You need to make sure the tranny is in reverse and the clutch is pushed in. I put a 2x4 between the clutch pedal and the seat to hold the clutch down.
I wish I would have known that yesterday! I took the entire valve assembly off to simply check the valve adjustment.
Jakey is offline
