View Poll Results: Where do I go from here? (now that all of the children have grown up...)
Build the X 17 56.67%
No one wants a $60k evo with high monthly payments, get out now and buy a 9. 13 43.33%
Voters: 30. You may not vote on this poll
Old 05-10-2010   #11
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Dave's Evo X Build
I'm not mad sir lol, the truth is we're months out on labor anyways I just wanted to get another Evo X build under our belt so we could further the market those services on a national and international level.
To clear things up, we were also open to using a new stock block to avoid the machining costs. I simply had to warn you that aftermarket pistons generally run larger piston to wall clearances and that we wouldn't know for sure that no additional hone would be necessary until we had all of the parts spec'd out. If you recall you were the one that didn't want any additional charges popping up down the line
Well thanks for clearing it up, it honestly wasn't an easy decision for me and I respect your honesty. I think truly the reason I ended up at DB was simply because I have Shane tune the car, so it would be easier to have one shop do the work and if something went wrong it wasn't a who's to blame thing.
I am happy that you don't hold a grudge, thank you for that. As I had said before, I like both shops very much. I guess it seemed through our emails/talks that you guys would've preferred to play it safe and bore/hone the motor. Obviously there is significant cost associated with that.
Regardless, thank you for your time Chris, i really do appreciate it.
Tags
casual mention of an evo, cold little murlo, daves sexcapades, flip flop, flip flopppp, hotdog crank polishing, manifold butthurt?, sexy time.
