Old 11-30-2010   #11
Re: Project Lex
I hope you're right I'm just basing my goals on my experience with my Talon (completely different car but about all I can personally compare to). This turbo is similar to the one I had on my Talon. Compared to the S362 I had on the Talon, this 84-75 I have for this car has an ever so slightly smaller comp wheel (appx 0.5mm smaller I believe), but a better exhaust side. And the Talon made 628 dynojet at 35psi, so that's pretty much all I'm basing my goal off. If you blow my goal away on the dyno (like you did with my Talon), well then you won't hear any complaints from me
Your dyno in 2wd mode reads a little closer to the dynojet numbers correct?
