Old 08-28-2015   #11
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
Re: My "new" car/project.
It turns out the brake deal isn't 100% as easy.
This is due to the weirdness of the 260z, as it's basically a mix between 240z and 280z depending on the part of the car and if it was early or late in the production run.
Anyway. The issue is that the spacer between the rotor and hub isn't a simple .500" think one like it otherwise might be. The "right" one ends up being .345" or so. Now, I can probably get this made how I would need it(for free, but, on someone's spare time), or buy a set for $120.
OR, and what I'll probably do.
This place just sells all of the stuff as a bolt-in kit. Complete with hardware, SS brake lines, and brake pads.
http://www.silverminemotors.com/dats...ke-kit-stage-4
The cost of a complete bolt in kit is ~$80-$100 more than you can get the parts for once shipping, sales tax, and core fees are figured in. If I go that route, I will ask if I can get rotors that are not slotted or drilled.
I would probably hop on that right now, if those brakes fit inside the stock 14" wheels I have right now, which they don't.
I still need to find a set of wheels I like that I can buy in both 5x4.5 and 4x4.5 (which is 114.3mm). The rear will be a 15 because drag radial sidewall. The front will be either 15 or 16.
I should be placing the order for the rear end parts in the next week. The newest batch of them has been produced and is available.
