Old 04-25-2018   #17
Mark Leasure
Mark Leasure's Avatar
Re: Mark's 1G Winter Projects
First off, thanks guys! This is going to be a building year for me, with so many changes.
The new chassis work is almost done. I had a problem with trim with the carbonetics fenders, the factory trim would not work. (Even with significant mods)
I learned that I needed to use Eclipse rear trim to eliminate the the eagle talon side/rocker trim. So fast forward, I removed the trim and it uncovered a rust spot on the passenger side and a big dent on the drivers side. I patched in new steel on the passenger side. This sucked, and was a good for me to learn body work...i also patched the holes for the trim mounting locations.
What is crazy is this was all done with custom paint mixed and 2k clear cost aerosol cans!
I also cutout the intercooler opening, I was unwilling to keep the front end closed off after research on the benefit. I built air guides on the intercooler to match the bumper profile.
Super pumped to get this project wrapped up and get it down the track!
www.maperformance.com
